Re: How to make and fasten removable firewall and floor panels?? [Re: Hemi Allstate] #2035712
03/21/16 01:44 PM
03/21/16 01:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By Hemi Allstate
Mike,
The gauges are Pro Comp Ultra Lite.
Mark
Thanks Mark.... how deep is the speedo head
wave
Mike ,
the gauge is about 3" deep past the dash face (1/8") but with the supplied Autometer mount, and wiring it is closer to 4". That could be reduced some I am sure, by trimming the mount, and using different mounting nuts, and electrical connectors. I modified the depth of the dash to make room.
Mark
Thanks.. I'm sure I can clear 3" and a bit more
but I dont have a lot of room behind the dash on
this L-body design... I was looking at a few of
the speedos and liked the style of what you have..
most of the others I didnt care for... IF my junker
doesnt fail in in the next couple of months I will
spring for the speedo/gauge kit.. also.. I assume the
sender came with it
wave
Re: How to make and fasten removable firewall and floor panels?? [Re: MR_P_BODY] #2035743
03/21/16 02:22 PM
03/21/16 02:22 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Mark [/quote]
sender came with it
wave [/quote]
Mike the sender does not come with the gauge.
It was another $85 or so.
Good luck with Drag Week , I hope you get in.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: How to make and fasten removable firewall and floor panels?? [Re: Hemi Allstate] #2035777
03/21/16 03:22 PM
03/21/16 03:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mark
sender came with it
wave [/quote]
Mark
[/quote]
wave
Re: How to make and fasten removable firewall and floor panels?? [Re: Hemi_Joel] #2036184
03/22/16 01:20 AM
03/22/16 01:20 AM
Minnesota
Hemi_Joel Offline OP
Minnesota
Hemi Allstate, that is amazingly sanitary and an inspiration, THanks, Vern, good idea for the seal.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: How to make and fasten removable firewall and floor panels?? [Re: Hemi_Joel] #2036257
03/22/16 04:44 AM
03/22/16 04:44 AM
Oh
His and Her 69's Offline
Oh
Joel here is mine on my old 69 RR.
It's similar to the one posted already.
Re: How to make and fasten removable firewall and floor panels?? [Re: His and Her 69's] #2036258
03/22/16 04:50 AM
03/22/16 04:50 AM
Oh
Oh
Mine is a 1 piece tunnel and it has a steel framework with dzus holes in the framework to hold the tunnel. There's 4 dzus fasteners around the front of the tunnel, and 2 on each side. There is a steel loop at the back with nuts welded to it for the shifter mount. Pretty easy to remove. Take the shifter off, 8 dzus fasteners, and slide it over out of the way.
David
Re: How to make and fasten removable firewall and floor panels?? [Re: Hemi_Joel] #2036455
03/22/16 02:08 PM
03/22/16 02:08 PM
Mt. Eden Ky.
Mt. Eden Ky.
Thanks Joel,
Good luck with your build. Your car looks to be in real nice shape.
Mark
1996 Ram 1500 Sport
1968 road runner
Re: How to make and fasten removable firewall and floor panels?? [Re: Hemi_Joel] #2038305
03/25/16 08:51 AM
03/25/16 08:51 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
For something used for street and strip we recommend buying an assortment of blind thread inserts.
