valve spring question #2032706
03/16/16 10:29 PM
03/16/16 10:29 PM
central new york
pettyblue440 Offline OP
central new york
im going to be buying a set of new heads with 509 springs. can I run these with a 484 cam or do I need to change them out? thanks, jon
Re: valve spring question [Re: pettyblue440] #2032817
03/17/16 12:39 AM
03/17/16 12:39 AM
what heads and what are those springs? More info please.
Re: valve spring question [Re: pettyblue440] #2033323
03/17/16 07:03 PM
03/17/16 07:03 PM
central new york
central new york
440 source stealth heads
Re: valve spring question [Re: pettyblue440] #2033367
03/17/16 08:38 PM
03/17/16 08:38 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
They say the springs on the Stealth heads are good for .510" lift, since your 484 cam only lifts .484" you're GTG.
Re: valve spring question [Re: pettyblue440] #2033374
03/17/16 08:47 PM
03/17/16 08:47 PM
dogdays Offline
dogdays  Offline
Yes, you can run them. Should be no problem.
Specs from catalog are:
Single with Damper. Recommended for maximum .510" lift, hydraulic flat tappet cams only. Over .510 lift, a dual spring is required, so we recommend upgrading to our 145-1013 Comp Cams Dual Valve Springs (per Comp's recommendation.)
Valve Spring Closed (seat) Pressure: Approx. 130 pounds @ 1.875" installed height
Valve Spring Open Pressure Approx. 330 pounds @ 1.275" (.600" lift.)
Valve Spring Inner Diameter: 1.050"
Valve Spring Maximum Lift: .510"
Valve Spring Coil Bind Height: 1.130"
Valve Spring Outer Diameter: 1.550"
Valve Spring Free Height 2.400"
Valve Spring Installed Height: 1.875"
Valve Spring Wire Diameter: .202"
Valve Spring Number of Coils: 5.5
This doesn't make sense, really. I suspect the free height is some sort of typo. Probably closer to 2.265" free height. I calculate 333lb/in as the spring rate.
A hydraulic flat-tappet should live with 130 on the seat and with your .484 cam the pressure over the nose or open pressure would be about 290lb.
It'd be interesting to find these springs in a catalog.
Looks like the springs could work to well over 0.600 but I think the concern is that that would be a pretty big cam and need some serious springs, probably quite a bit more spring rate.
Online I found these springs that are mighty close to the specs, just a little different.
Elgin RLGRV-9941XK
Anyway, no need to have more spring than you already have, although I'd sure look into a different cam if you haven't bought the .484 already.
R.
