Re: t-ram vs single 4500
[Re: KOS]
#2030269
03/13/16 02:59 PM
03/13/16 02:59 PM
Thumperdart
State of confusion
I`m going t-ram next........better distribution and looks bad azz to boot..............I`ll go 2 750`s more than likely..........
[Re: KOS]
#2030289
03/13/16 03:28 PM
03/13/16 03:28 PM
Posts: 562 Ohio
lockjaw-express
Ohio
I am looking to do the same on a 604" motor, and I have a stage V Dual quad intake on the way...thought about 2x Quick Fuel 1000 or 1050 4150 carbs for it.
Just have to decide on Annular or standard boosters...still have to mount them sideways, and the car/engine will be street/strip, but I figure the 4150 would be more streetable.
Not really a tunnel ram, but I want it to fit under the hood.
BR, Mark
[Re: KOS]
#2030334
03/13/16 04:47 PM
03/13/16 04:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
[quote=FastmOp]Go EFI on the T-ram. Then your ready for a power adder [/quo
alot of changes to go that route would have to be really worth it......fill me in on the details. I was gonna do just that.. I had the parts to do either a W-2 or W-5.. but I changed my mind only because I didnt want to cut the cowl hood and have the throttle bodies above the hood.. mainly for rain being a DW car.. I have 2 extra throttle bodies and the tunnel rams for each set up.. I bought the Holley multi point EFI and went with a single plane... really all it would cost IF you wanted to go injected would be the extra throttle body.. again IF you have the TM
[Re: KOS]
#2030347
03/13/16 05:17 PM
03/13/16 05:17 PM
Posts: 2,933 A shed in England
Tig
A shed in England
We made a few mistakes on ours but all will be good in time
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: KOS]
#2030349
03/13/16 05:26 PM
03/13/16 05:26 PM
MR_P_BODY
I assume you have a TR.. but if you werent thinking of injection then its gonna cost about $2300 to go with a TR and injected.. its a bit pricey on the hit but I did it.. for the single injected(single plane) its more like $1900 for the complete package... it has its bennies
[Re: KOS]
#2030538
03/13/16 09:56 PM
03/13/16 09:56 PM
MR_P_BODY
remote start....im sold LOL ok next question what system is reconmended? I went with Holley.. mainly because its a self learning system.. but it also has data logging
[Re: KOS]
#2030589
03/13/16 10:42 PM
03/13/16 10:42 PM
Thumperdart
State of confusion
ya no question about better distribution thump im more stuck on what carbs i would use???im looking for max gain but i also like alittle bit of streetability.....would dual doms be worth it?or pair of 1050 4150s be close enough?has anyone played with this??? I`ll never jump on the efi wagon cos I`m not a quitter and love the challenge of making carbs work..........easy no, but I don`t buy the "efi makes more power bs" look at Pro stock. Carbs cool the intake charge better and make more power up to a point so in your case find out how much cfm you need and have a couple built by who ever.............
[Re: KOS]
#2030626
03/13/16 11:10 PM
03/13/16 11:10 PM
Posts: 562 Ohio
lockjaw-express
Ohio
I talked to Ray Barton last week, and he told me that a direct injection intake and the new Holley EFI is the way to go. I asked him about The FastEfi, and he told me that the direct injection is much better.
I was talking to him about mid height TP intakes and the Stage V intake, and he told me buy the Edelbrock single plane with direct port injection...but, I like my old ways, and chose to go with the lower Stage V intake, and and then contemplate running modified 800 cfm Edelbrocks (modded to 1000cfm) or go with the Quick Fuel Q-Drag race carbs.
I guess I am in the same boat as Thumperdart.
Mark
[Re: KOS]
#2030641
03/13/16 11:25 PM
03/13/16 11:25 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Big cubes, big cam, big converter. I think you are going to need more than dual 750's. 1050 Dommy's might be a little too much, but somewhere in between. Maybe a set of 950's?
[image][/image]
[Re: Thumperdart]
#2030645
03/13/16 11:30 PM
03/13/16 11:30 PM
MR_P_BODY
ya no question about better distribution thump im more stuck on what carbs i would use???im looking for max gain but i also like alittle bit of streetability.....would dual doms be worth it?or pair of 1050 4150s be close enough?has anyone played with this??? I`ll never jump on the efi wagon cos I`m not a quitter and love the challenge of making carbs work..........easy no, but I don`t buy the "efi makes more power bs" look at Pro stock. Carbs cool the intake charge better and make more power up to a point so in your case find out how much cfm you need and have a couple built by who ever............. Dom.. you do know why the HP is lower on them.. its not due to efi... its the lack of rpm.. like 1500 less... some day you will join this century
