Re: Tips and Tricks for Loosening K-Member Bolts [Re: loco340cuda] #2027033
03/08/16 03:29 AM
03/08/16 03:29 AM
New York, USA
Chargerfan68 Offline
New York, USA
You can get a spray can straw of PBblaster through the frame holes and squirt plenty of PBblaster on the bolts inside the frame for a few days. That did wonders for all the Kframe bolts I have removed. came out Real easy!
Re: Tips and Tricks for Loosening K-Member Bolts [Re: loco340cuda] #2027177
03/08/16 01:25 PM
03/08/16 01:25 PM
AndyF Offline
AndyF  Offline
Shouldn't have any problem with a car from AZ. I've pulled a lot of K frames out in the wrecking yard here in OR. Just get the car up in the air and use a 1/2 inch breaker bar and out they come. The bolts usually look brand new. I have a dozen or so of them in my bolt drawer and they all look nice and clean with the plating still on them. Western cars aren't like the rusted hulks back east.
Re: Tips and Tricks for Loosening K-Member Bolts [Re: loco340cuda] #2027294
03/08/16 04:59 PM
03/08/16 04:59 PM
Madrid, IA
hellrzr Offline
hellrzr  Offline
Madrid, IA
I didn't have an impact when I did mine so I used PB Blaster and MAP gas. Got the area red hot and they finally broke lose. An impact should help a lot though.
Re: Tips and Tricks for Loosening K-Member Bolts [Re: loco340cuda] #2027319
03/08/16 05:51 PM
03/08/16 05:51 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Originally Posted By loco340cuda
I don't have an air compressor so i will have to use a breaker bar.
Can you beg/borrow a decent electric or cordless impact?
And keep in mind if you hose the bolts down with flammable penetrating chemicals to be extremely careful if you end up needing to apply heat.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Tips and Tricks for Loosening K-Member Bolts [Re: Evil Spirit] #2027363
03/08/16 07:03 PM
03/08/16 07:03 PM
We wouldn't want another member in the hospital for K member issues. (I ain't sayin you ain't carefull tho!)
