Re: setting timing on blower motor
[Re: ffej]
#2025060
03/05/16 03:43 PM
03/05/16 03:43 PM
Posts: 43,286 Bend,OR USA
Cab_Burge
To find the best timing for any motor, power adder or N/A you need to know how much total timing you have it set at to start with Do you know how much your total advance is now? If so what is it? If you don't know you need to be able to find out :thumbs :Many things contribute to what the motor will like for total timing like the quality of the fuel being use, the amount of boost being made, the spark plug type and heat range and even the manifold intake temperatures below the blower Please give us some more information on your combination like static compression ratio, lbs of boost at max RPM, your spark plug type and heat range and your current total timing Ultimately you will need to set the timing at a safe amount and then watch the spark plugs, all eight of them and thne try advancing the total timing two more degrees at a time until the motor starts to run worst Once you find that you back it down one or two degrees and run that The last blower motor(426 Hemi) I tuned on a dyno liked 33 degrees total timing with 7 lbs of boost at 7300 RPM, we switched the pulleys to go from 12% under driven to 13 % overdriven which made 12 lbs of boost at 6500 RPM, I had retarded the timing to 25 degrees total timing and we had switched it to race gas in it from the pump gas we had used to tune it with the lower boost. It didn't like 25 degrees so we advanced it to 27 degrees and it hated that We put the pulleys back and took it off the dyno as we where running out of time and the owner was real happy with the resuts we had got on pump gas, his car was not going to hook up with 925 HP on pump gas , let alone with 1027 HP on race gas IHTHs
[Re: ffej]
#2025154
03/05/16 06:45 PM
03/05/16 06:45 PM
Posts: 4,210 New York
polyspheric
New York
that makes me feel kind of stupid Not at all, quite the reverse - you investigated before you broke something.
As you must have anticipated, the maximum timing will get smaller as boost goes up, high boost engines use as little as 18 degrees.
Boffin Emeritus
[Re: ffej]
#2025424
03/06/16 01:19 AM
03/06/16 01:19 AM
Cab_Burge
To figure the initial timing at idle RPM you use a timimg light to see where it is idling at To figure total timing you need either a harmoinc balancer that has timing marks on it from 0 to 60 in 2 degree increments or a after market balancer that is marked that way. Another option is to use a timing tape on a stock balancer but that is a crap shoot if your balancer is on the motor and not absolutely clean before using and applying the timing tape I have had them blow off due to not good enough cleaning and not using a clear varinsh or clear coat of paint over the tape after installing them Once you have a balancer that you can read the timing with the motor revved up you can mark with white marker or something easy to read to mark what you want to see, say mark 25, 30, 35 and 40 degrees so they are easy to see to start with Another way is to use a dial back timing light and see what you have at idle, dial it back to zero and then revved the motor until it quits advancing the timing and then dial that back to zero, that will be the total advance read on the dial on the back of the timing light when revved up beyound the mechanical advance Do you have a decent timing light? Is your balancer or steel blower hub marked like needed to read the total advance? If not on either then you need to get that done to see what you have, it is way better on a blower motor to have to little advance than to much Unless you want to melt the pistons in the motor under boost Just kidding , but please don't melt the pistons while learning
[Re: ffej]
#2025678
03/06/16 01:10 PM
03/06/16 01:10 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Plug reading,,,,,E/T, and MPH will tell you the sweet spot.
[Re: ffej]
#2025766
03/06/16 03:45 PM
03/06/16 03:45 PM
Posts: 31,073 Oregon
AndyF
it has a mallory unilite distr. how do you determine total advance or figure out how much initial timing you have / im really green on this stuff but id like to learn as much as i can. Do you have a timing light?
[Re: ffej]
#2025936
03/06/16 08:29 PM
03/06/16 08:29 PM
polyspheric
New York
MPH will tell you something, but it's potentially dangerous. Pick a conservative figure (like 25), run it a fixed distance, and advance 1 degree at a time, watch for the MPH to go up (if it doesn't, pick a lower number and start over). When it stops increasing speed (viz. advanced 1 degree but no better MPH), STOP. Retard to the previous setting. If the plugs are light, add jet size and try again.
Remember, all of this presumes the same axle, tire OD, chassis weight, boost, water and oil temp, exhaust system, plugs, air cleaner, and jetting.
Boffin Emeritus
[Re: ffej]
#2026002
03/06/16 09:34 PM
03/06/16 09:34 PM
AndyF
yes i have a standard timing light not the kind mentioned with dial. Okay, does your damper have timing marks on it for the first 60 degrees or so? If not then either buy a different damper or put some timing tape on your damper. Once you have that set up then just fire up the engine and see where your timing is at. Slowly rev up the engine and watch what the timing does. You should be able to figure out initial and total advance by doing this unless your distributor has a super slow curve in it. I'm assuming that you don't have vacuum advance hooked up but if you do you'll need to unhook it while you're trying to figure out what your initial and total timing are.
[Re: ffej]
#2028797
03/10/16 09:25 PM
03/10/16 09:25 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
thanks for the answers and patience with my lack of knowledge. im beginning to understand the total timing thing but how do i find ideal initial timing? or the best way to get close to initial timing to start figuring it all out? as far as plugs go if they look like running lean im too advanced right? no, timing and A/F ratio are different. if your worried about timing read the ground strap. http://www.dragstuff.com/techarticles/reading-spark-plugs.html Joe
Without Data, you’re just another guy with an opinion.
