M body shorty headers #2015906
02/20/16 04:05 AM
02/20/16 04:05 AM
USA
JoesMopar Offline OP
USA
Does anyone know what shorty headers fit an M body? Or are they all pretty much universal? I'm running a 10:1 276/513 Voodoo cam 360 with factory manifolds and am currently dealing with a 2" pipe running from the manifolds to my 2 1/2" dual exhaust. I'd like to ditch them for a pair of shorties to run 2 1/2" the entire way. Long tube headers are out of the question since I'm using the fast ratio pitman and idler arms. I figure the shorties would flow enough, be able to connect to 2 1/2" pipe, and will still be high enough to work around the pitman/idler when routing the new 2 1/2" pipe.
Thanks for any help
Re: M body shorty headers [Re: JoesMopar] #2016585
02/21/16 01:45 PM
02/21/16 01:45 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Schumachers shortys are high quality and expensive. I dont know if they fit the M body- they are not listed for the M body.
http://engine-swaps.com/Pages/ProductsType/SB_Headers.html
Keep old mopars alive.
Re: M body shorty headers [Re: JoesMopar] #2016593
02/21/16 02:06 PM
02/21/16 02:06 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Look up Sanderson and see if they have anything for the small block. Probably not that specific, application, but maybe close enough?
Re: M body shorty headers [Re: JoesMopar] #2016644
02/21/16 04:23 PM
02/21/16 04:23 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
B-body long tubes fit these cars so any shorty for that app should work IMHO.
No torsion bars in the way helps.
Kevin
Re: M body shorty headers [Re: JoesMopar] #2016768
02/21/16 07:52 PM
02/21/16 07:52 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If they show a list for F bodies it should fit the M as well, same chassis. Looking at Summit I only see long tubes listed for the F body. I imagine rear dumps like for a Magnu 360 might work, but I'd hesitate to buy a set for a test fit myself.
Don't be the exception.
Re: M body shorty headers [Re: Supercuda] #2019559
02/25/16 04:39 PM
02/25/16 04:39 PM
USA
USA
Thanks alot guys.
Re: M body shorty headers [Re: JoesMopar] #2021634
02/29/16 01:03 AM
02/29/16 01:03 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Are you sure your fast ratio arms won't clear long tube headers? I recall the headers that don't fit all being big block headers. I would call Firm Feel if it's their arms you have on the car.
All the shorty small block headers I've seen either hit the steering box or the firewall.
On a side note: you will eventually destroy long tube headers on that car if you're still running the factory torsion bars.
