Re: 17" wheels and tires on 70-74 Cuda (Any links or pictures)?
[Re: GOT6PAK]
#2010738
02/12/16 08:21 PM
02/12/16 08:21 PM
Posts: 7,664 IN
ahy
IN
Here is a close cousin with 17's. 1970 Challenger running AR Salt Flat Specials. 17x8 front with 235/45/17 and 17x9.5 rear with 265/40/17. These are ultra high performance Dunlops which are low profile. Done again I would go with 18's to get a bit more tire diameter with the ultra low profile tires. With "standard" tires, lots of selection in 17's. I think you will have a hard time fitting 255's on the front w/o rub. OE was something like 215 or 225. Also check tire specs for wheel requirements... the 255's you are looking at may be a bit wide for an 8" width. Wheel to tire sizing gets more sensitive with the lower profile tires. As you go wider in tires, backspacing needs to be dialed in just right. I measured and ordered my wheels with custom backspace. No extra charge, just took a couple of weeks. Good luck and please post a pic.
[Re: ahy]
#2010793
02/12/16 09:25 PM
02/12/16 09:25 PM
Posts: 892 Southern California
GOT6PAK
Southern California
@ahy, your combo looks good. I'm trying to get a little more side wall and not as low profile. My car has 245/60-14's all the way around which are 25.6" tall and 9.8" overall width which is really close to a 255/45-17 in height and width. The 255/45-17 is 25.97" tall and 10.08" wide so I figured it was close. The rear 255/50-17 is 27.09" tall and 10.43" wide which I'm hoping will tuck nice in the rear with the 4.81" back space 17x8's. I'm hoping someone is running something similar so I can see how it looks. [img:left] [/img] 14x7's with 4" back space and 245/60-14's
[Re: GOT6PAK]
#2021591
02/28/16 10:51 PM
02/28/16 10:51 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
[Re: GoodysGotaCuda]
#2021680
02/29/16 01:36 AM
02/29/16 01:36 AM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
I ran 245/45/17 front and 255/45/17 rear on 17x8 inch rims on my 1970 challenger. They fit great. Nowadays they are just collecting dust though as I've gone to a 19x10 setup with 275/35/19's at all four corners.
Keep in mind, on front tire clearance you gain a ton of room on the larger diameter rims once you can clear the upper ball joint.
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
[Re: Tom_440]
#2022260
02/29/16 11:22 PM
02/29/16 11:22 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Mine are 17x9 with 5" backspacing front and back. Ended rolling the fender lips in the back. Running 275's all around. Anything changed front suspension wise?
#2022395
03/01/16 02:18 AM
03/01/16 02:18 AM
Posts: 5,160 Las Vegas, NV
Tom_440
Las Vegas, NV
Mine are 17x9 with 5" backspacing front and back. Ended rolling the fender lips in the back. Running 275's all around. Anything changed front suspension wise? There is a TVS kit sitting on the floor next to the car
[Re: GOT6PAK]
#2022803
03/01/16 08:48 PM
03/01/16 08:48 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Mine are 17x9 with 5" backspacing front and back. Ended rolling the fender lips in the back. Running 275's all around. Anything changed front suspension wise? There is a TVS kit sitting on the floor next to the car Well that's close! I need to reassess my front wheel selection once my car goes back together. I definitely prefer to have more backspacing up front than I do today. You are at 25.7" tall for the 275/40/17, I am at 26.0" for the 255/45/17 I have today. I'd like to get a little bit of a taller tire up front, but I love the lip showing on yours as well. Certainly worth considering the change.
[Re: GOT6PAK]
#2023450
03/02/16 08:49 PM
03/02/16 08:49 PM
Posts: 299 Jacksonville Fl
70BigBlockSE
Jacksonville Fl
70BigBlockSE, looks good but what are the specs? Looking for rim width, back space and tire size. Also, are there any clearance issues with your combo. Thank you! Mine are Torq-Thrust II fronts 17x7(4"backspace) with Nitto 555 Extreme 235/45ZR17 and rear 17x8(4.75" backspace) with Nitto NT 450 275/50R17. I do have Doctor Diff 10.5" cobra disc kit on the back. Have plenty of clearance on leafs and fenderwell. Almost wish I would have gone to a 245 tire in front
