Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget
[Re: Adam71Charger]
#2018995
02/24/16 07:48 PM
02/24/16 07:48 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Were 440s that went into imperials assembled any different than 440s that went into cheaper cars like furys or trucks? What compression ration and heads should I expect from this motor?
Production line engines were not built for a specific car, they were built to a spec and shipped from engine plant to assembly plant where they are pulled from stock as needed.
[Re: Adam71Charger]
#2019032
02/24/16 08:38 PM
02/24/16 08:38 PM
Posts: 3,896 St. Louis, MO
Blues_Cuda
St. Louis, MO
Just for conversation sake, we had a '74 440 in our '64 Savoy back in the early 90's that we called the $200 440. (We paid $200 for both the motor/trans out of an Imperial or equivalent barge.) I took it apart, dingle berry honed it, put in some cheap rings/bearings, and added a used .509 MP cam/lifters, Doug Herbert springs, swap meet Team G and 750 Holley DP. (Not even new rod bolts. ) With a 10" Street Fighter converter and 4.56 gears, the '64 ran 12.80's. With a fresh valve job and a factory Max Wedge intake/600 Carters, it ran 12.40's @ 108mph every time we raced it. The thing would never skip a beat and it ran fine when it was pulled in 2001 for the 'good' motor. It was plenty streetable, but highway drives were a little short with the 4.56s. The 285/70 BFGs calmed that down a bit at least. We joked that it did not have enough power to blow itself up.
[Re: Blues_Cuda]
#2019184
02/25/16 12:10 AM
02/25/16 12:10 AM
Posts: 20,184 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Just for conversation sake, we had a '74 440 in our '64 Savoy back in the early 90's that we called the $200 440. (We paid $200 for both the motor/trans out of an Imperial or equivalent barge.) I took it apart, dingle berry honed it, put in some cheap rings/bearings, and added a used .509 MP cam/lifters, Doug Herbert springs, swap meet Team G and 750 Holley DP. (Not even new rod bolts. ) With a 10" Street Fighter converter and 4.56 gears, the '64 ran 12.80's. With a fresh valve job and a factory Max Wedge intake/600 Carters, it ran 12.40's @ 108mph every time we raced it. The thing would never skip a beat and it ran fine when it was pulled in 2001 for the 'good' motor. It was plenty streetable, but highway drives were a little short with the 4.56s. The 285/70 BFGs calmed that down a bit at least. We joked that it did not have enough power to blow itself up. NICE, nice and simple. I had a block once that was so worn out and I had to finish the season with it. I dingle honed the block and put double cast rings in it. (cast top and 2nd). That sucker ran like you wouldn't believe and sealed up great.
[Re: Adam71Charger]
#2019536
02/25/16 03:52 PM
02/25/16 03:52 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
B&M makes a line of flexplates that are designed for that.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Paul_Fancsali]
#2019714
02/25/16 08:29 PM
02/25/16 08:29 PM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
Do not use a 509 cam in a low comp engine you will make the car a pig I would concentrate as stated on heads and engine dist running all the total I could get the car to run/ start with in normal fashion Run a hyd cam of around 480-490 lift keep the centerline at around 112 Good intake and exhaust If you can try a 350 horse from late 60 early 70s still around and cheap if still in a car. Do not pay any attention to the Mopar bible for total timing limits of 36 or so Give the engine all it can take and back off when she barks. Run a 650-750 dbl pumper 650 for throttle response 750 if you can for overall power and drag racing.
Have fun and just do it ! You dont think 509 cam even with 4.10 gears and 3000 stall?
[Re: Adam71Charger]
#2019739
02/25/16 08:47 PM
02/25/16 08:47 PM
Posts: 2,079 CA
crackedback
CA
Have fun and just do it ! You dont think 509 cam even with 4.10 gears and 3000 stall? If you have the 509 that's one thing. If you have to buy, then get the 108LSA 484 if you want to run a mopar hydraulic cam. The 509 might make more power in the last 500 rpm and it's not going to be by much. The 484 will pull the midrange better. Especially if you advance it a bunch as mentioned earlier. I'd run a Lunati Voodoo 60303 or 60304 cam before the Mopar cams.
