BRAKE FLUID
#2017439
02/22/16 03:40 PM
02/22/16 03:40 PM
Posts: 608 TN
1DGEMAN
TN
We are getting ready to put brake fluid in the Cuda. It is a original owner numbers matching 440 6bbl 4sp. It has all new brake components. It will be driven once or twice a month. The owner wants me to put DOT 5 fluid in it because of worry about long term hydroscopic problems and the remote chance of DOT 3 or 4 getting on the paint. What do you guys use?
Real Men shift for themselves
Re: BRAKE FLUID
[Re: 1DGEMAN]
#2017447
02/22/16 03:44 PM
02/22/16 03:44 PM
RapidRobert
It has all new brake components. It will be driven once or twice a month. The owner wants me to put DOT 5 fluid in it because of worry about long term hydroscopic problems and the remote chance of DOT 3 or 4 getting on the paint. What do you guys use? that sounds like an excellent candidate for DOT 5
Re: BRAKE FLUID
[Re: 1DGEMAN]
#2017682
02/22/16 10:02 PM
02/22/16 10:02 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Use the DOT 5 and never worry again. We use it in older postal vehicle with no problems.
Re: BRAKE FLUID
[Re: 71birdJ68]
#2017805
02/23/16 12:44 AM
02/23/16 12:44 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
I can't get dot 5 to seal up and quit leaking. I run Dot 5 and haven't had any issues with leaking? It did take a while to get properly bled (but that said, I have 8 piston front and 4 piston rear calipers) but no drips or leaks anywhere. (flex lines were all new, hard lines were half new and half older)
Re: BRAKE FLUID
[Re: 1DGEMAN]
#2017966
02/23/16 11:57 AM
02/23/16 11:57 AM
Posts: 12,253 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
We have used DOT 5 for 20+ years in multiple vehicles. No problems what so ever and we have not changed any out either.
Master, again and still
Re: BRAKE FLUID
[Re: DaveRS23]
#2018006
02/23/16 01:05 PM
02/23/16 01:05 PM
Posts: 608 TN
1DGEMAN
TN
Thanks everyone. Put the DOT 5 in the car last night. None of the parts stores around here had it in stock so had to order it. Came from wharehouse in a couple of hours. Bench bled the master cylinder. Vacuum bled then gravity bled the brakes. The pedal is great no paint problems.
