69 barracuda brakes #2016655
02/21/16 04:33 PM
02/21/16 04:33 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
I'm fixing up a 69 barracuda and am having no luck getting rear brakes on to work on the car. I installed all new wheel cylinders and a new master cylinder, bleed from brakes and got a decent brake pedal, but I can't get any rear brakes. When bleeding the pedal doesn't go down, I believe the portioning/distribution block may be bad. The car has sat since 1992 and I'm working on making it road worthy again. How offer does this occur and who sells them?
Re: 69 barracuda brakes [Re: DusterKid] #2016657
02/21/16 04:40 PM
02/21/16 04:40 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
I would be suspect of the rear rubber hose being plugged first.
Re: 69 barracuda brakes [Re: T2R9] #2016797
02/21/16 08:41 PM
02/21/16 08:41 PM
first find where it is plugged. seperate the hard line from the rear neoprene hose & if still plugged then take off the rear line at the splitter and is it a 4 wheel drum splitter or a disc prop valve
