A-body four speed driveshaft length??
#201668
01/23/09 01:01 AM
01/23/09 01:01 AM
Posts: 8,144 Arkansas
340727dart
Arkansas
I got my new four speed bolted up tonight. I know I need to either lengthen the drive shaft previously used with the 727, or just get a new one made. But, I need to know just how much to have added. How much free movement back and forth should there be with the drive shaft yoke on the tail shaft of the transmission? Thanks.
Your life is not my fault. My life is none of your business.
Speech is free only if you agree with those in control.
Re: A-body four speed driveshaft length??
[Re: 340727dart]
#201670
01/23/09 09:23 AM
01/23/09 09:23 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
I could measure mine except I have a 7 1/4. I am sure the nose on that is different than the 8 3/4.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: 340727dart]
#201671
01/23/09 11:39 AM
01/23/09 11:39 AM
340727dart
Arkansas
I guess what I need to know is how far the drive shaft yoke should extend into the transmission. How much movement back and forth do I need to compensate for suspension movement so that the yoke doesn't bottom out on the transmission's output shaft and to prevent it from pulling out of the transmission?
[Re: 340727dart]
#201676
01/24/09 01:08 AM
01/24/09 01:08 AM
Posts: 5,270 Missouri
MY340
Missouri
TK, I'd get a new heavy duty driveshaft made if I were you. A shop in Arnold, MO did a 3" custom one for me with solid race u-joints and it was much stouter than the original. If I remember correctly it cost me around $250. You have around a 400hp 340-4spd now twisting on that factory driveshaft. You don't want to spit that driveshaft out from under the car on a burnout or 6000rpm shift.
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
