Re: Time for a new Holley ?
[Re: ccdave]
#2017434
02/22/16 03:36 PM
02/22/16 03:36 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Yea that's it! Very cool car. And he is from Illinois. He inspired me to go with more cubic inches so the rest of the car could be built more streetable.
[Re: ccdave]
#2017692
02/22/16 10:17 PM
02/22/16 10:17 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Big cubes, smallish cam, tall gears.......I would steer clear of "race" calibrated carbs if you're going to buy something off the shelf. That type of combo just doesn't need the same type of low speed calibration a more race oriented combo would, and it can sometimes be a chore to get them to run clean in the part throttle cruise mode.
While it contradicts what Russ's results were in his car, I like the plain ole 850 double pumpers in that type of application. Custom?? I'd probably try and have something done out of the QFT "950" style body with the 1.450 Venturi.
I also like the old Demon RS combo with the 1.420 sleeves and the 1.750 base plate...... The "825", although the calibration they came with ootb was awful.
[Re: ccdave]
#2017991
02/23/16 12:43 PM
02/23/16 12:43 PM
Posts: 304 Florida
Mark Whitener
Being a dual plane intake distribution will be much better with an annular booster. Quick Fuel has 1.45, 1.50, and 1.59 venturi bodies available, I would use at least the 1.50 with an annular or a 1.59. I use BLP baseplates in my builds, the t-slot are smaller like the Holley bases and control transition fuel better, so ideally a custom is a better way to go. BLP also has billet bodies available if you want the look of billet, in either a shiny silver or a coated black version.
Mark Whitener [url=www.racingfuelsystems.com[/url]
[Re: ccdave]
#2018081
02/23/16 03:09 PM
02/23/16 03:09 PM
fast68plymouth
So. Burlington, Vt.
I would agree that if you're going to use annular boosters, a 1.50 Venturi is probably the smallest you'd want for that displacement.
[Re: ccdave]
#2018237
02/23/16 07:19 PM
02/23/16 07:19 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
my 512 is very close to your engine, I also have 3.23 gears 68 charger, I bought a holley 950 hp & the cruise afr was down in the high 10s, it took a lot of tuning to get it mid 13s, changed the primary metering block that has adjustable IFRs,but that was another $120.00 it works ok.
[Re: CSK]
#2018245
02/23/16 07:35 PM
02/23/16 07:35 PM
Posts: 2,094 central texas
krautrock
central texas
my 512 is very close to your engine, I also have 3.23 gears 68 charger, I bought a holley 950 hp & the cruise afr was down in the high 10s, it took a lot of tuning to get it mid 13s, changed the primary metering block that has adjustable IFRs,but that was another $120.00 it works ok. what IFR did the holley have and what did you end up with? the adjustability of the QFT carbs is pretty appealing.
[Re: krautrock]
#2018278
02/23/16 08:41 PM
02/23/16 08:41 PM
CSK
Pattison Texas
my 512 is very close to your engine, I also have 3.23 gears 68 charger, I bought a holley 950 hp & the cruise afr was down in the high 10s, it took a lot of tuning to get it mid 13s, changed the primary metering block that has adjustable IFRs,but that was another $120.00 it works ok. what IFR did the holley have and what did you end up with? the adjustability of the QFT carbs is pretty appealing. the best i could tell it had .035 IFR & 70 IAB, now .028 IFR, .058 IAB
[Re: CSK]
#2018289
02/23/16 08:50 PM
02/23/16 08:50 PM
fast68plymouth
So. Burlington, Vt.
my 512 is very close to your engine, I also have 3.23 gears 68 charger, I bought a holley 950 hp & the cruise afr was down in the high 10s, it took a lot of tuning to get it mid 13s, changed the primary metering block that has adjustable IFRs,but that was another $120.00 it works ok. This is why I prefer to use "street" calibrated carbs for that type of application.
[Re: fast68plymouth]
#2018331
02/23/16 09:19 PM
02/23/16 09:19 PM
Thumperdart
State of confusion
ANY carb(except svo`s can be tuned for the street quite easily......do it all the time even into the 8-second zone but agree the QF and newer Holleys w/billet features are nicer, lighter and better over all...........
[Re: ccdave]
#2018340
02/23/16 09:32 PM
02/23/16 09:32 PM
Posts: 31,049 Oregon
AndyF
Boy, lots of options!!!!! I have the ability to get a Holley at cost so my options for other brands is a no go because I'm a cheap Mopar guy.. Does Holley make a HP series vacuum secondary carb in a 850/950? Their listings are all over the board????? Not that I know of. There is a 870 cfm Avenger carb #80870 but I've never used it. Might work okay on a street driven stroker. There is also the 850 Speed Demon carb which Holley sells. Not sure if your at cost deal includes Demon's or not.
[Re: ccdave]
#2018468
02/23/16 11:58 PM
02/23/16 11:58 PM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
If you are on a tight budget, buy a used 4781 and a rebuild kit. For less than $225 you'll be very close for a bunch less money. I did run mid 11.70s at 119.5+ mph with the 850.
