Re: 318 LA block with magnum heads compression ratio?
[Re: alpha727]
#201646
01/23/09 12:14 AM
01/23/09 12:14 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
unless you know what the deck height is on the pistons...head cc...pistons cc.. head gasket cc..
you would be guess....
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: alpha727]
#201647
01/23/09 12:15 AM
01/23/09 12:15 AM
Posts: 6,167 Maryland
GO_Fish
Maryland
you will pick up about 1/2 point compression, maybe a little more doing only the Mag head swap.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: GO_Fish]
#201648
01/23/09 09:50 AM
01/23/09 09:50 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
no you won't if it's a 2bbl...OEM magnums usually run in the 63cc chamber range, the stock 302 heads usually run in the 58-63cc range, so your compression won't change dramatically, adn might decrease slightly..
I have an '86 318 out of my 5th ave and measured it, at TDC the pistons are about .085 in the hole. with this measurement, if you use a thin head gasket (say, a .028", 4.06" bore), you're looking at 8.6:1 compression with a 63cc chamber. using a .040" gasket drops it to 8.4, using a head gasket that comes in a kit (most that come in the fel-pro kits are .054" compressed thickness) will take you south of 8.2:1.
[Re: Wedgeman]
#201651
01/23/09 01:11 PM
01/23/09 01:11 PM
patrick
Grand Haven, MI
the open chamber 318 heads actually run closer to 68cc. the closed chamber 302's usually run in the 58-62cc range.
[Re: alpha727]
#201653
01/23/09 02:13 PM
01/23/09 02:13 PM
Posts: 576 Escondido, CA
kick_the_reverb
Escondido, CA
My stock open chamber 675 type 318 heads were 64 cc Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto Finally - disc brakes on the front. In the plans - rear disc brakes, B&M 250 blower
[Re: alpha727]
#201656
01/23/09 02:53 PM
01/23/09 02:53 PM
patrick
Grand Haven, MI
If I get the magnum heads than more than likely I will have to get new pistons to raise the compression ratio to where I want it to be and all of the other things that go with the magnum swap. But, if I go 302's I can keep the stock pistons and mill the heads put in bigger valves and do a port job they would probably end up costing close to the same amount but, I think the 302's would outflow the magnums when compared.
sorry, wrong answer. a nearly max ported 302 with bigger valves will flow about the same as an OOTB magnum head on the intake side, and be down about 30cfm on the exhaust. chamber volume on the 302's is very close to a magnum, within about 3-5cc, which will be about the same amount of volume (and compression) difference as a .028 vs. a .054" thick head gasket. which why not just mill the magnum heads a bit?
if you're paying for port work, enginequest magnums will be significantly cheaper. 318B's have the LA intake bolt pattern. Carolina Machine Engines (www.cmengines.com) is a distributor and will set them up for $650-900 depending on what you want for valves and springs. just getting a used set of 302 heads done with new valves, springs, and machine work (no port work), you're probably up in the $500 range.
another option would be to disassemble the short block and deck the block .050 or so if the bores are in good shape and you don't want to buy pistons.
[Re: patrick]
#201658
01/23/09 03:09 PM
01/23/09 03:09 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
notice how I said in stock form. A lot of people would not want to port them themselves, and it costs $$$ to have that done. Either one of these head sets are fairly prone to cracking so I'd be worried about going hog wild on these heads. Plus, to be at the magnum's flow you need to buy new valves and have machining done for that.
my entire magnum conversion, including heads didn't even cost $450 and I even bought the MP R/T springs and retainers.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: alpha727]
#201661
01/23/09 04:44 PM
01/23/09 04:44 PM
patrick
Grand Haven, MI
the flow for a max effort 302 and OOTB enginequest heads will be comparable on the intake, but the 302 will be down about 30cfm on the exhaust.
when Dulcich built the "junkyard jewel" 318, IIRC his flow results after extensive porting, 2.02/1.60 valves maxed out in the 200/150 (int/ex) range. IIRC RyanJ maxed ported a set of 302's and installed bigger valves, and he got ~240/150 (int/ex) on his bench. but these are basically professional porters with a flow bench at their disposal, not a backyard hack (no offense).
most tests I've seen on the enginequests (sold by Hughes as "iron rams") place the peak flow at 215-230/170-180 (int/ex) out of the box with stock valves.
also, if you hog out the 302's to near 360 size, you will probably run into issues--the set Dulcich did on his 400HP "junkyard jewel" motor cracked and sprung a coolant leak in one of the intake ports about 6 months after that article was published because the casting was too thin after porting.
also, what size cam are you planning on running? with stock pistons (no valve reliefs) you may start getting into valve-to-piston clearance at lifts greater than ~.480" lift.
when I contacted CME about a year ago, they quoted me $650/pr + ship for EQ318B's, 3 angle valve job, OEM valves, seals, & keepers, and GM3100 springs & retainers set up at 1.65" IH. those springs installed at that height should be good for a cam to about .51" lift or so. they also quoted me $850/pr for the same heads, but with 2.02/1.625 SB chev valves .1" longer than stock, 5 angle valve job, and springs for a hydraulic roller cam good for .55" lift.
and if you wanted more power down the road, the EQ mag heads max out in the 280/220 range for int/ex flow max ported.
[Re: patrick]
#201662
01/23/09 04:49 PM
01/23/09 04:49 PM
patrick
Grand Haven, MI
it's hard to say. honestly, it'll probably be a wash. max ported 302's might make a little more torque because the runner will still be about 20cc smaller than a magnums, so they'll have a little bit more velocity at low RPMS. but they might run out of breath sooner, too.
on the flip side, the magnum has a little better chamber, which will help it more....but unless you're near 0 deck for good quench, the slight improvement in chamber design probably won't be significant.
also, the poor exhaust port of the 302's might hurt some too.
[Re: patrick]
#201663
01/23/09 06:44 PM
01/23/09 06:44 PM
goldduster318
Lake Orion, MI
here's an article using a 318 with zero deck pistons and stock and ported magnum heads: http://www.popularhotrodding.com/tech/0810phr_chrysler_318_engine/index.htmlI run box stock magnum heads on an under 9:1 (probably more like 8.6:1) 360...I know its a bigger engine, but its got great torque and horsepower. you can't feel it "lay down" at all anywhere from idle to 5500 (I don't spin it over that since its a somewhat loose used short block). I actually am able to get "too much" ignition advance so it will start missing at idle and won't start easily with this engine. I doubt it will change your 318's compression much at all. I had the same heads that are on my 360 on an 89 318 with stock pistons that ran decent (had minor carb issues though before it had a bearing spin). Obviously, the 360 is going to be stronger, but if you've ever driven a 318 magnum powered pickup, you'll know they make good torque as well.
[Re: GO_Fish]
#201666
01/24/09 11:00 AM
01/24/09 11:00 AM
Posts: 2,251 ILLINOIS
volaredon
ILLINOIS
My bad. I was comparing the Mag compression against an old open chamber 318 head, not against a closed chamber 302 head(not sure what year they started with the 302's). I agree, compression between a Mag head and a 302 head would be minimal.
That's what I was thinking as well, being that both 318s I have are completely dead stock (one even has its Lean Burn still) My 78 Fury has '163 heads and not sure which heads my '83 P/U has but I'm thinking they are the exact same ones on there too. Both are still 2 barrel motors (not for long!) CR wise, yeah; the 302s will be about the same as the Magnum heads; I seem to remember seeing they were rated at like 8.9-9.0:1 but if you run stock Magnum rocker gear you will pick up a bit in rocker ratio which will help things even if onlt a little; also I'm thinking an LA 318 with Mag heads will be real close CR wise and performance wise to a stock Mag 318.especially if both are running the same intake and carb.
[Re: goldduster318]
#201667
01/24/09 12:21 PM
01/24/09 12:21 PM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
I would go for the magnum heads... actually the EQ heads. With a 2.03 intake valve and porting they got flow numbers of 275/int -- 229ex at .600 lift........ that is pretty decent for some cheap cast iron heads.... TBF
71 Challenger 528 Hemi project 09 Gr Cherokee 5.7 hemi in da house!!
