Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget
[Re: Adam71Charger]
#2036684
03/22/16 07:23 PM
03/22/16 07:23 PM
Posts: 8,237 fredericksburg,va
cudaman1969
fredericksburg,va
Been seeing this post but never responded till now. Not sure if it helps now but.. I bought my 64 Plymouth in 92, it came with a 74 stock 440, torker intake, holly dp and I put a 509 cam and springs. Never been apart. Come with good vert and 4.88 gears, 14-32 tires ladder bars. I only ran 1/8 mile and ran 7.78 et at 94 mph. Don't know what hp that equates to but pretty good for a 8 to 1 comp. engine. Maybe one of the other guys can say how much. Unless the engine you buy has a lot of ring ridge, put in new rings, maybe a valve job and add ons then go with it
[Re: Adam71Charger]
#2036922
03/23/16 01:34 AM
03/23/16 01:34 AM
Posts: 10,201 Someplace you aren't
SomeCarGuy
If the engine cant be ran to observe stuff and a teardown isnt going to happen before hand, just see if it turns over smoothly. That's not to say it is great inside, but you can feel/hear if things are totally Fubared.
I want my fair share
[Re: Adam71Charger]
#2037347
03/23/16 07:35 PM
03/23/16 07:35 PM
Posts: 74,977 U.S.S.A.
JohnRR
U.S.S.A.
Can a machine shop get close to a zero deck without having to assemble the rotating assembly into the block? Im asking here first because so I dont confuse things in translation to the machinist.
I remember in the past the shop had to mock up the engine to get measurements before decking and that was an extra $200. Im wondering if they can measure the height of the tallest piston/rod combo and deck to that height without have to mock up the block. Only if he is able to take accurate measurements of ALL the involved parts and that is time, and time is MONEY. It's going to cost you less I would imagine for the guy to drop the crank in on 3 set of bearings and move one rod/piston combo to the 4 corners of the block and measure where the high and low points are and then cut the block. Or ask him if he'll let you do it and tell him which corner to cut and how much to cut off.
[Re: Adam71Charger]
#2037465
03/23/16 10:40 PM
03/23/16 10:40 PM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
I called Jim at Racer Brown. Gave him the info on my engine and its intended use. about 4100lbs with driver. automatic, 3000 stall & dana 60 4:10. With the flat top pistons at zero deck, 84cc combustion chambers, bowl blended sidewinder heads, and 1.7 rockers hes grinding me a solid single pattern cam with 254 duration @50, .554" lift, and I think he said 106 LSA. and the advance will ground into the cam.
He did say my stall will work, but I should upgrade to a custom made 5000 stall by a company he recommended. He says it will actually slip less than my 3000.
[Re: LaRoy Engines]
#2037473
03/23/16 10:54 PM
03/23/16 10:54 PM
Adam71Charger
Alright, after 2 weeks of waiting got the block bored and honed +30, tanked and new cam bearings. Confirmed today.
In the meantime I was able to turn a good profit on the stuff I wouldnt be re-using from the engine. So, I decided to invest in some extras.
Tod at Marsh Performance is preparing some 84cc sidewinder heads with a bowl blend and isky springs for a solid cam and is setting me up with an adjustable 1.6 rocker/shaft kit for a good price. He says the springs will handle up to low 6 lift.
Got 440 source stock replacement forged rods, got my steel crank turned 10/10, and Ive found some TRW/Speed pro 6-pack pistons #L2355F.
So this is where Im at now, picking a cam. I cant find any information online about the max lift I can use with these pistons.
Calling a few cam grinders but always like to hear ya'lls opinions on cam selection.
Will probably be close to 10:1 without touching the decks and using the felpro .039 gasket. Would like to use thinner gasket, but don't know if its wise.. In fact, Ive been urged to zero deck the block which Id love to but dont know if I can afford it. Another example, I didn't have to recut the pistons until I went to the solid roller. old 440 with 6-pack pistons All your links and information has been very helpful along the way, thank you
