Re: Hemi deck height
[Re: cudaman1969]
#2013899
02/17/16 01:38 PM
02/17/16 01:38 PM
Posts: 75,080 U.S.S.A.
JohnRR
U.S.S.A.
Hemi is same as RB , it's 10.725, 10.59 would be .135 short. You create other problems with that much off.
I'm not sure what you would use for a spacer with that much off , shim gaskets and ??? sandwiched in the middle ?
[Re: JohnRR]
#2013912
02/17/16 02:03 PM
02/17/16 02:03 PM
Posts: 8,325 fredericksburg,va
cudaman1969
fredericksburg,va
I'm not sure what you would use for a spacer with that much off , shim gaskets and ??? sandwiched in the middle ? I had read somewhere about a spacer that came in different thickness, made for the old SS blocks, Sandwiched between two gaskets. Of course copper and the MLS gaskets can be had that are 1/4 thick, but not sure of the integrity of that.
