Page 4 of 4 1 2 3 4
Re: Mopar 337 intake info and pics here. [Re: Azzkikrcuda] #2266445
03/09/17 10:13 PM
03/09/17 10:13 PM
North Dakota
Azzkikrcuda Offline OP
North Dakota
Intake ports marked to match the heads. Intake lines up good with ports in head.
The only Carbs I care about are under the hood!
Re: Mopar 337 intake info and pics here. [Re: Azzkikrcuda] #2266791
03/10/17 02:21 PM
03/10/17 02:21 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I'll be getting a set of those heads to do that same thing to sometime this summer.
Going to be used with a factory x-ram.
Although, I'm looking at that pic of the MW gasket on your head and wondering if there is going to be a fitment issue with the top of the intake runner and that ridge on the intake flange of the head.
Re: Mopar 337 intake info and pics here. [Re: Azzkikrcuda] #2312009
05/27/17 02:47 PM
05/27/17 02:47 PM
NORTH CAROLINA
aaronj Offline
aaronj  Offline
NORTH CAROLINA
Would anyone by chance know how tall this intake is?
Re: Mopar 337 intake info and pics here. [Re: aaronj] #2312134
05/27/17 09:19 PM
05/27/17 09:19 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
I'll go measure mine for you, I have the TF heads, just tell me where you would like the measurement from.
Re: Mopar 337 intake info and pics here. [Re: Azzkikrcuda] #2312576
05/28/17 08:01 PM
05/28/17 08:01 PM
NORTH CAROLINA
aaronj Offline
aaronj  Offline
NORTH CAROLINA
Could you measure from the intake valley plate up to the carb base? If there is a gap from the block valley to the intake valley cover could you take another measurement from the engine block valley edge to the carb base? Thank you for the help!
Re: Mopar 337 intake info and pics here. [Re: Azzkikrcuda] #2312996
05/29/17 02:40 PM
05/29/17 02:40 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
It was pretty tough to get a good eye but about "4.75 from block valley surface to carb base.
Re: Mopar 337 intake info and pics here. [Re: Azzkikrcuda] #2313006
05/29/17 03:00 PM
05/29/17 03:00 PM
NORTH CAROLINA
aaronj Offline
aaronj  Offline
NORTH CAROLINA
Awesome, thank you. I think this thing is actually slightly lower than my 6 pack intake.
Page 4 of 4 1 2 3 4
