Re: Mopar 337 intake info and pics here.
[Re: Azzkikrcuda]
#2015274
02/19/16 09:55 AM
02/19/16 09:55 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
You can put a smaller port intake on a larger port head, but not the other way around. Air crashes into the wall where it is mismatched and really messes up flow. If the intake port is smaller than the head, it acts more like an anti-reversion setup. Just remember that your flow is only as high as the smallest port.
[image][/image]
[Re: Azzkikrcuda]
#2017034
02/22/16 01:14 AM
02/22/16 01:14 AM
Posts: 571 Spring Hill Fl
65Fury440
Spring Hill Fl
Rough measurement of how much the intake ports on a Std. port Trick Flow head will need to be opened up to work with this intake. To the outside of the markings, Should be around a 2.47 x 1.32 port opening. Azzkikr, do you plan on opening up your TFs to match the 337? I am interested in doing this. Is there a lot meat on top of the port? Please share pics if you do, and thanks for the info so far.
[Re: 65Fury440]
#2017577
02/22/16 06:51 PM
02/22/16 06:51 PM
Posts: 1,811 North Dakota
Azzkikrcuda
North Dakota
After talking with Dwayne P. the current plan is to open up the Trick Flow Ports to work with this manifold. There is a lot of room to work with on the top of the port. Will probably raise it slightly more then my earlier outline. Overall size will be smaller then max wedge. I will post some pics, but I will be awhile before a get a chance to start on it.
The only Carbs I care about are under the hood!
[Re: Azzkikrcuda]
#2030549
03/13/16 10:10 PM
03/13/16 10:10 PM
Azzkikrcuda
North Dakota
Started on roughing in the head ports, Decided on a 2.55 x 1.35 port size.
[Re: Azzkikrcuda]
#2030550
03/13/16 10:12 PM
03/13/16 10:12 PM
Azzkikrcuda
North Dakota
Now I have to start working the ports in.
[Re: Azzkikrcuda]
#2030566
03/13/16 10:26 PM
03/13/16 10:26 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Looks good, I agree with definitely raising the port like in the pics.
Keep us posted on the progress. I bet you end up with one heck of a set of Trick flow high flowing heads.
If they flow 330 or so stock, Id like to see your flow numbers after you get done.
[Re: 65Fury440]
#2134020
08/16/16 12:44 AM
08/16/16 12:44 AM
Azzkikrcuda
North Dakota
I finished opening up the intake ports and they tuned out good. I will probably send one to Dwayne to see what it flows, when I get a chance. I will post flow numbers if I do.
[Re: AndyF]
#2218568
12/21/16 08:30 PM
12/21/16 08:30 PM
Posts: 17,915 S.E. Michigan
ZIPPY
S.E. Michigan
Is there a lowdeck version of the 337? Nope. (not unless you consider Stage VI heads on a low deck) Mopar Performance could've built one, but the chances of than happening now are zero. They don't even like the 337 intake that they do have! They killed it off a few years back and Zippy got them to bring it back after I wrote a magazine article telling everyone about it. But I don't think there is anyone left at MP anymore who cares about big block engines. Agreed, I don't think so either, and thank you for the name drop, I probably wouldn't have found this thread otherwise. Glad I was able to get a couple small things done for the hobby and post about part availability while I was there, but was very low on the totem pole and limited as to what I could do/who would listen. Hope to get after it again and be a civilian, now that I've been away from it for awhile.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2218609
12/21/16 09:45 PM
12/21/16 09:45 PM
Posts: 5,160 Texas
dannysbee
Texas
Nice to see you post Zippy. Have a Merry Christmas!
Getting old just means you were smarter than some and luckier than others.
[Re: dannysbee]
#2219078
12/22/16 04:16 PM
12/22/16 04:16 PM
ZIPPY
S.E. Michigan
Nice to see you post Zippy. Have a Merry Christmas! You too dannysbee, thank you
Rich H.
Esse Quam Videri
[Re: BradH]
#2219109
12/22/16 05:09 PM
12/22/16 05:09 PM
ZIPPY
S.E. Michigan
Nice to see you post Zippy. Have a Merry Christmas! x2 from me. Aw man. You too Brad, thank you sir.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2219348
12/23/16 12:01 AM
12/23/16 12:01 AM
Posts: 4,704 Wichita
GY3
Wichita
Rich! Holy cow, thought maybe you jumped ship and bought a Porsche or something.
Good to see you, buddy!
[Re: GY3]
#2219733
12/23/16 05:46 PM
12/23/16 05:46 PM
ZIPPY
S.E. Michigan
Mark...thanks...still around, just a whole lot less, and not getting very much done that anyone here would want to read about...
Rich H.
Esse Quam Videri
[Re: Azzkikrcuda]
#2219740
12/23/16 06:03 PM
12/23/16 06:03 PM
Posts: 1,545 USA
hudsonhornet7x
USA
Zippy, You have a pm
OK tried to pm, said you were over your limit.
[Re: hudsonhornet7x]
#2222957
12/29/16 08:27 PM
12/29/16 08:27 PM
ZIPPY
S.E. Michigan
Sorry, just deleted a few hundred. Will send you a message.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2266443
03/09/17 10:11 PM
03/09/17 10:11 PM
Azzkikrcuda
North Dakota
Started working on this project again. Ended up using the Superformance Max Wedge size gaskets on the heads. I did not port the floor lower, I shifted the gasket up to get the roof higher. The intake matches the floor of the port perfectly with only a small void where the gasket goes lower.
