I know this has been covered a lot. And I apologize. I did this conversion years ago on my 70 Dart. I just picked up a 73 Duster last month. However, it's got factory drum front brakes on it. I'm confused reading tech articles and what not. They say you will need "73-76 upper control arm". Does that mean all I need is the spindle setup? Obviously I'd need calipers etc. What do I need to scavenge for my 73 drum car? Thanks guys. I appreciate it.
I always point folks to this article.
http://www.moparaction.com/Tech/archive/disc-main.htmlYou'll need disk brake spindles and believe it or not, E body spindles will work! If you don't mind 15" wheels, the 1976 up 11.75" unicast cop disk brakes are the bomb to do on the cheap, provided you can source the calipers and disks still. If not, there's info on stock A body disks in that article too. I did this swap on the Bee. Easy Peezy.
