Master Cylinder/Power Booster-Plated or Painted? #2011385
02/13/16 10:20 PM
02/13/16 10:20 PM
Central Texas
b_body_fan Offline OP
Central Texas
I have a 1971 Charger with power disc brakes(Midland-Ross type booster). Should the power brake booster be painted or plated? I have seen some with paint and some plated in gold cadmium. Could painted and plated boosters both be correct? If that's the case, does it vary from assembly plants. What about the master cylinder? I have seen painted and natural cast master cylinders with plated boosters, and with painted ones.
Re: Master Cylinder/Power Booster-Plated or Painted? [Re: b_body_fan] #2011401
02/13/16 10:38 PM
02/13/16 10:38 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
If you mean the pancake booster, then it's plated and there is a decal that goes on it.
Re: Master Cylinder/Power Booster-Plated or Painted? [Re: b_body_fan] #2011489
02/14/16 12:34 AM
02/14/16 12:34 AM
None
71rm23 Offline
71rm23  Offline
None
Booster and M/C cover plated. Used RPM on the body of the M/C
Re: Master Cylinder/Power Booster-Plated or Painted? [Re: 71rm23] #2011596
02/14/16 03:54 AM
02/14/16 03:54 AM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
Looks nice but that's an aftermarket master cylinder.
NOS 71-'74 master cylinders I've had were coated with a gray coating, body, bale wire and lid. For lack of a better description I'd call it a parkerized finish.
Only exceptions I've seen were the carry over "9191" disc brake master used on '70 and '71 hemi E and B bodies, and the 72-74 manual disc brake master cylinder, both of which were painted black, including the bale wire and cap.
Re: Master Cylinder/Power Booster-Plated or Painted? [Re: Mastershake340] #2011678
02/14/16 12:50 PM
02/14/16 12:50 PM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
This is an NOS master that I put on my 71RR. Don't know what the finish is called?? From my research that's what I came up with. There was no gold cap on 71's. Also the brake booster was gold cadium plated not painted.
Re: Master Cylinder/Power Booster-Plated or Painted? [Re: 71rm23] #2011695
02/14/16 01:33 PM
02/14/16 01:33 PM
None
71rm23 Offline
71rm23  Offline
None
My M/C is not original to the car. I originally had drum, now discs. I am aware of he colors,etc but went this route to make the booster and wiper motor look similar
Re: Master Cylinder/Power Booster-Plated or Painted? [Re: b_body_fan] #2011822
02/14/16 04:29 PM
02/14/16 04:29 PM
Central Texas
Central Texas
I guess it looks like I need to refinish my master cylinder and booster. They are both original to the car, so I won't be worrying about finding correct pieces. My brake booster is in really good shape with no rust or any kind of pitting from what I can tell, its just painted. If the plating is good under the paint, anyone have a suggestion how to remove the paint without damaging the plating?
Re: Master Cylinder/Power Booster-Plated or Painted? [Re: b_body_fan] #2011863
02/14/16 05:43 PM
02/14/16 05:43 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Just take the booster apart. 71 boosters are easy to disassemble and reassemble.
