70-71 Cuda Shaker Hood Carb Height 383 #2008660
02/09/16 05:06 PM
02/09/16 05:06 PM
MN
Droop69 Offline OP
Droop69  Offline OP
MN
I am getting ready to install my original Holley 6193 carb on the motor (383), and was wondering if there was a carb spacer or special gasket that was used.
When I got the car it had an aftermarket 750 Holley installed, and a stack of gaskets.
I wanted to make sure I get the bubble height correct.
Pics would be great if anybody has some.
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: Droop69] #2008690
02/09/16 06:17 PM
02/09/16 06:17 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Been awhile with 383 Shaker cars , I know you need the carb spacer, IIRC it's 3/4" thick
here's some pics of a 383 set up and the parts needed, some of the pics are from Terry (Mccannix) IIRC, I'm sure he'll have some more pics/info if he sees this thread
Mike
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: Droop69] #2008707
02/09/16 06:37 PM
02/09/16 06:37 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
A gentleman in NY repro'd these some years back and are very good.
Pm me and I'll see if I can dig up his contact info
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: mccannix] #2008712
02/09/16 06:46 PM
02/09/16 06:46 PM
MN
Droop69 Offline OP
Droop69  Offline OP
MN
Any pics or part number for the carb spacer?
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: mccannix] #2008714
02/09/16 06:46 PM
02/09/16 06:46 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Terry any info/pics on the required carb base spacer, IIRC it's 3/4"?
Mike
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: Droop69] #2008905
02/09/16 11:24 PM
02/09/16 11:24 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Here's a few more....make sure you have a 383 shaker base as they are different than the 340/440 4bbl base, IIRC the 340/440 neck is 1 1/2" tall and the 383 is 2" deep
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: Droop69] #2009031
02/10/16 01:53 AM
02/10/16 01:53 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Mike
I'm not 100% sure on the carb gasket but you may be correct at 3/4".
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: mccannix] #2009194
02/10/16 01:26 PM
02/10/16 01:26 PM
MN
Droop69 Offline OP
Droop69  Offline OP
MN
Thanks for the pics guys. I do have the correct 383 base, but I am also missing the support rod you guys showed.
I will post a pic of the spacer that was under the carb when I bought the car.
Does anybody have some good pics of the wiring of the idle solenoid and the relay on the distributor?
Thanks,
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: Droop69] #2009684
02/11/16 02:30 AM
02/11/16 02:30 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Thanks,
The best I can do is some 1970 factory lit, take it with a grain of salt as engineering photos and production may change
Mike
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: DAYCLONA] #2009884
02/11/16 03:19 PM
02/11/16 03:19 PM
MN
Droop69 Offline OP
Droop69  Offline OP
MN
Thanks Mike. Good information. A little hard to find.
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: Droop69] #2010137
02/11/16 09:41 PM
02/11/16 09:41 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Tom
I pm'd you info on Chris from NY who makes the rod.
I think the carb gasket is: Holley HLY-108-18
Terry
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: Droop69] #2010493
02/12/16 03:11 PM
02/12/16 03:11 PM
Frederiction. New Brunswick ,C...
RTshaker Offline
RTshaker  Offline
I`d like to see a picture of the 3/4 in spacer when you get to it ..
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: mccannix] #2010640
02/12/16 07:07 PM
02/12/16 07:07 PM
MN
Droop69 Offline OP
Droop69  Offline OP
MN
Thanks Terry, I will try and see if he still is making them.
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: RTshaker] #2010646
02/12/16 07:11 PM
02/12/16 07:11 PM
MN
Droop69 Offline OP
Droop69  Offline OP
MN
This is what was on my car when I got it. I am not sure if this is the OEM spacer or not. I have never seen an original 4 BBL shaker spacer.
Does this look like an OEM piece?
On close inspection it does look bonded together really well.
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: Droop69] #2012485
02/15/16 03:40 PM
02/15/16 03:40 PM
MN
Droop69 Offline OP
Droop69  Offline OP
MN
Anyone have pics of an original 4bbl carb Shaker spacer?
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: Droop69] #2012897
02/16/16 01:29 AM
02/16/16 01:29 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The proverbial "unicorn" of Shaker parts!!!! I'd like to see/have a pic for my files as well, last one I laid my eyes on was on Steven Seigel's 1971 GY3 383 Shaker Cuda convertible...where's the plethora of Shaker gurus when you need them smile
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: Droop69] #2012937
02/16/16 02:25 AM
02/16/16 02:25 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Technically not a shaker part but a carb/intake part.
As stated above Holley HLY-108-18 should be the gasket you need.
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: mccannix] #2012949
02/16/16 02:40 AM
02/16/16 02:40 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Terry, wouldn't there be 2 gaskets required?, one under the carb, and one under the spacer?..same gasket?, or alternate PN?
mike
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: DAYCLONA] #2013256
02/16/16 04:57 PM
02/16/16 04:57 PM
MN
Droop69 Offline OP
Droop69  Offline OP
MN
That's what I was thinking. I have not seen any pics of an original spacer. Possible unicorn...?
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: Droop69] #2013680
02/17/16 01:42 AM
02/17/16 01:42 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I cant comment because I have never had the opportunity to look close at an original 383 shaker carb, etc with the system removed
