Small Block water pump with outlet on driver side?
#201054
01/22/09 04:15 PM
01/22/09 04:15 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I think most SB water pumps have the outlets on the passenger side but the one I had was on the driver side and I need another one but I don't know how to order one. Does anyone know what year and car they came on and can you get a high performance one?
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: Small Block water pump with outlet on driver side?
[Re: WadeMetzinger]
#201056
01/22/09 04:35 PM
01/22/09 04:35 PM
RapidRobert
late 60's 273 have cast iron WP's w drivers inlet & are shallower compared to the 70 & up aluminum units that have a pass inlet. MP offers an 8 blade heavy duty one but it is pricey. I would get a parts store 8 blade(non A/C) one & add a round anticavitation disc to the impeller. Need more info? gotta lot of time? go here www.moparchat.com & scroll down to & click on circle track chat & checkout Mr Sanborns cooling mods that are in a sticky at the top of the page. One of the countries foremost SB cooling experts. All the cooling info you need (& then some). Plan on several hours to absorb it all. Plus alot can be easily adapted to BB as well.
[Re: WadeMetzinger]
#201058
01/22/09 04:41 PM
01/22/09 04:41 PM
RapidRobert
You want the WP that has the inlet on the same side as your rad nipple. the early(cast iron) WP's MAY only come in a 6 blade & the later alum ones MAY(I am not sure) have a thicker impeller which would move more water. But I would strongly suggest you read Sanborns material.
[Re: RapidRobert]
#201059
01/22/09 10:19 PM
01/22/09 10:19 PM
Posts: 3,333 MARYLAND
69Cuda340S
MARYLAND
With the lower hose on the driver's side? You have a part number or link because I don't see it out there. I don't see ANYTHING other then stock replacement pumps with the lower hose on the driver's side??
[Re: RapidRobert]
#201060
01/22/09 10:31 PM
01/22/09 10:31 PM
RapidRobert
I meant the 70 & up alum pass side pump could be had in a HD app(& 8 blade) MP iirc P5249559 & it was pricey. I dont think there's anything available for the dr inlet except for the garden variety replacement 273 units. I reread my post & my wording was misleading
[Re: RapidRobert]
#201061
01/22/09 11:20 PM
01/22/09 11:20 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
Flow Kooler makes a high flow model of the early LA water pump. It is cast iron and pricey. early LA cast iron water pump There WERE cast aluminum versions of these early LA pumps available, but they are pretty scarce. Most you will find are iron. I found an NORS aluminum pump on Egag.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
