cable kick down for a small block? #2008165
02/08/16 08:56 PM
02/08/16 08:56 PM
South Dakota
hotairballoonpilot Offline OP
South Dakota
Has anyone used one before? Dad was told about them and asked me to check into it. Its on a 72 cuda 340 auto car.
Contact Me about AMD Prices
Re: cable kick down for a small block? [Re: hotairballoonpilot] #2008229
02/08/16 10:48 PM
02/08/16 10:48 PM
Toronto, Ontario, Canada
plazomat Offline
plazomat  Offline
You mean like...
http://www.bouchillonperformance.com/trans_kickdown_cables
go with these guys nothing but good things. I have a lokar and don't like it and you can find some cheap ebay ones as well if you dare...
PLAZ
Re: cable kick down for a small block? [Re: plazomat] #2008452
02/09/16 11:06 AM
02/09/16 11:06 AM
moparx Offline
moparx  Offline
my experience with a bunch of lokar setups has not had one installation that was worth a hoot. i got the privilege [?] of TRYING to make them work. the bracketry is very weak and bends easily after installation, and the CORRECT adjustment is impossible to get right without re doing levers, brackets, etc. then the terminating end is not very stout either. the cables stretch without effort to boot. just stay away from 'em !
beer
Re: cable kick down for a small block? [Re: hotairballoonpilot] #2008609
02/09/16 04:05 PM
02/09/16 04:05 PM
South Dakota
South Dakota
thanks guys. I looked at the web site but says no linger available. I emailed them to see what is still there.
Any other suppliers?
corey
Re: cable kick down for a small block? [Re: hotairballoonpilot] #2008647
02/09/16 04:45 PM
02/09/16 04:45 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
Looks available to me for $145. I have one on my Charger.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: cable kick down for a small block? [Re: hotairballoonpilot] #2008738
02/09/16 07:27 PM
02/09/16 07:27 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
LINK TO cable kit
Re: cable kick down for a small block? [Re: hotairballoonpilot] #2008756
02/09/16 07:56 PM
02/09/16 07:56 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i don't have any complaints with the lokar on my truck
i put a qft baseplate on my carb so maybe the lokar works better with that throttle lever than some others...idk
