63 Plymouth and 65 Plymouth Jack assembly #2008692
02/09/16 06:17 PM
02/09/16 06:17 PM
Texas
6pkRB Offline OP
6pkRB  Offline OP
Texas
Can anyone with an original 63 Plymouth Belvedere and a 65 Plymouth Belvedere jack assembly, please post some detailed pictures of each?
Thanks,
Randy
Re: 63 Plymouth and 65 Plymouth Jack assembly [Re: 6pkRB] #2009915
02/11/16 04:17 PM
02/11/16 04:17 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Here is from our original '65 Satellite… hope this helps. Any more specific questions?
Cheers, - Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: 63 Plymouth and 65 Plymouth Jack assembly [Re: 67SATisfaction] #2010721
02/12/16 09:06 PM
02/12/16 09:06 PM
Texas
6pkRB Offline OP
6pkRB  Offline OP
Texas
Art,
Thanks that helps for the 65.
Now if I can find the same information for a 63.
Randy
Re: 63 Plymouth and 65 Plymouth Jack assembly [Re: 6pkRB] #2011018
02/13/16 12:09 PM
02/13/16 12:09 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Randy I might have everything for a 1963. I will look. I'll get you some pictures.
Getting old just means you were smarter than some and luckier than others.
Re: 63 Plymouth and 65 Plymouth Jack assembly [Re: 6pkRB] #2011073
02/13/16 02:14 PM
02/13/16 02:14 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Here is 63 Fury hook which is the same for 63 Polara. Part #2266627 They visually stick out cause of the pointed part of the hook all others hooks are straight across...
