Re: 70-71 Cuda Shaker Hood Carb Height 383
[Re: Droop69]
#2008905
02/09/16 11:24 PM
02/09/16 11:24 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Any pics or part number for the carb spacer? Here's a few more....make sure you have a 383 shaker base as they are different than the 340/440 4bbl base, IIRC the 340/440 neck is 1 1/2" tall and the 383 is 2" deep
[Re: Droop69]
#2009684
02/11/16 02:30 AM
02/11/16 02:30 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Thanks for the pics guys. I do have the correct 383 base, but I am also missing the support rod you guys showed.
I will post a pic of the spacer that was under the carb when I bought the car.
Does anybody have some good pics of the wiring of the idle solenoid and the relay on the distributor?
Thanks, The best I can do is some 1970 factory lit, take it with a grain of salt as engineering photos and production may change Mike
[Re: RTshaker]
#2010646
02/12/16 07:11 PM
02/12/16 07:11 PM
Posts: 961 MN
Droop69
MN
This is what was on my car when I got it. I am not sure if this is the OEM spacer or not. I have never seen an original 4 BBL shaker spacer.
Does this look like an OEM piece?
On close inspection it does look bonded together really well.
[Re: mccannix]
#2012949
02/16/16 02:40 AM
02/16/16 02:40 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Technically not a shaker part but a carb/intake part. As stated above Holley HLY-108-18 should be the gasket you need. Terry, wouldn't there be 2 gaskets required?, one under the carb, and one under the spacer?..same gasket?, or alternate PN? mike
[Re: ek3]
#2013728
02/17/16 02:47 AM
02/17/16 02:47 AM
Posts: 18,157 Mass
DAYCLONA
Mass
pretty sure the 340 and 383 base plates are 3/8" in height diff. just traded with mike ross .. he was careful to be sure it was in fact a 340 plate I had ... the adapter looks like it is about 3/8" to me ? just a thought .. When you say "base plates", I'll assume you mean the actual Shaker base/carb plate", and the adapter you saw? did you have it, or Mike Ross? here's the Shaker base chart
[Re: mccannix]
#2563354
10/13/18 12:48 PM
10/13/18 12:48 PM
Posts: 3 Norway
The Norwegian
Norway
Hi Would be nice to have contact data to this gentleman who made this rods. Thanks Arne
71 Challenger Shaker
[Re: The Norwegian]
#2563672
10/14/18 12:43 AM
10/14/18 12:43 AM
Posts: 1,175 Woodbridge
Tommy The Chryco
Woodbridge
Hi Would be nice to have contact data to this gentleman who made this rods. Thanks Arne Will have them available next month!
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
[Re: Tommy The Chryco]
#2565406
10/17/18 03:25 PM
10/17/18 03:25 PM
Posts: 961 MN
Droop69
MN
That's awesome! I never could get a hold of the guy that made the 1st run of reproductions.
You have to wonder how rare of a part the factory original support rods are? I have never seen a factory original one on a car or at a swap meet.
