Re: 70-71 Cuda Shaker Hood Carb Height 383
[Re: Droop69]
#2008905
02/09/16 11:24 PM
02/09/16 11:24 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Any pics or part number for the carb spacer? Here's a few more....make sure you have a 383 shaker base as they are different than the 340/440 4bbl base, IIRC the 340/440 neck is 1 1/2" tall and the 383 is 2" deep
[Re: Droop69]
#2009684
02/11/16 02:30 AM
02/11/16 02:30 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Thanks for the pics guys. I do have the correct 383 base, but I am also missing the support rod you guys showed.
I will post a pic of the spacer that was under the carb when I bought the car.
Does anybody have some good pics of the wiring of the idle solenoid and the relay on the distributor?
Thanks, The best I can do is some 1970 factory lit, take it with a grain of salt as engineering photos and production may change Mike
[Re: RTshaker]
#2010646
02/12/16 07:11 PM
02/12/16 07:11 PM
Posts: 961 MN
Droop69
MN
This is what was on my car when I got it. I am not sure if this is the OEM spacer or not. I have never seen an original 4 BBL shaker spacer.
Does this look like an OEM piece?
On close inspection it does look bonded together really well.
[Re: mccannix]
#2012949
02/16/16 02:40 AM
02/16/16 02:40 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Technically not a shaker part but a carb/intake part. As stated above Holley HLY-108-18 should be the gasket you need. Terry, wouldn't there be 2 gaskets required?, one under the carb, and one under the spacer?..same gasket?, or alternate PN? mike
