Master Cylinder - Brake line adpter fitting size? #200858
01/22/09 11:34 AM
01/22/09 11:34 AM
...gently down the stream
LAR_414 Offline OP
LAR_414  Offline OP
What is the size of an adapter fitting for a MP Alum Master Cyl, to a standard 3/16 brake line with standard ends on it?
Re: Master Cylinder - Brake line adpter fitting size? [Re: LAR_414] #200859
01/22/09 12:51 PM
01/22/09 12:51 PM
AndyF Offline
AndyF  Offline
Which fitting? The front fitting (rear brakes) is different than the rear fitting (fron brakes). They are different so people won't get them messed up.
The correct fittings are available at any Dodge dealer. You might need a good parts guy to help you find them though.
Re: Master Cylinder - Brake line adpter fitting size? [Re: AndyF] #200860
01/22/09 12:59 PM
01/22/09 12:59 PM
LAR_414 Offline OP
LAR_414  Offline OP
Yeah, I need the one for the front port (rear brakes).
I got "the biggest one they had" at Advance auto, and it's too small.
Re: Master Cylinder - Brake line adpter fitting size? [Re: LAR_414] #200861
01/22/09 01:03 PM
01/22/09 01:03 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The Right Stuff has them. In fact, they have new (complete) master cylinder lines.
Re: Master Cylinder - Brake line adpter fitting size? [Re: DoctorDiff] #200862
01/22/09 01:44 PM
01/22/09 01:44 PM
LAR_414 Offline OP
LAR_414  Offline OP
Cass,
The Right Stuff doesn't ring a bell. Is that a store or a brand?
Larry
Re: Master Cylinder - Brake line adpter fitting size? [Re: LAR_414] #200863
01/22/09 02:08 PM
01/22/09 02:08 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Got a lot of that crap at the shop
Re: Master Cylinder - Brake line adpter fitting size? [Re: LAR_414] #200864
01/22/09 02:31 PM
01/22/09 02:31 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
That is a business name.
Any store that makes repro brake lines (The Right Stuff, Classic Tube, Inline Tube, Fine Lines) will have them.
