Re: W2 casting # 4532689
[Re: Streetwize]
#2010263
02/12/16 12:49 AM
02/12/16 12:49 AM
Posts: 20,180 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Well, (heaven help me) I bought everything you see here.
Every time I try to get out, something pulls me back in! Parts hoarder. Lol
[Re: Streetwize]
#2010285
02/12/16 01:13 AM
02/12/16 01:13 AM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
It was those cool dual colored plug wires....sealed the deal right there!! And the belt drive pulleys
[Re: Streetwize]
#2010537
02/12/16 04:33 PM
02/12/16 04:33 PM
Posts: 4,457 Washington
madscientist
Washington
I saw the twin colored wires. I figured it was a go fast circle track thing.
What dizzy is that?
[Re: Streetwize]
#2011251
02/13/16 06:44 PM
02/13/16 06:44 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Certainly are milled, look at the surface you can see the milling marks and they look heavy like someone was trying to take away a lot of metal (or they were just in a hurry).
[Re: madscientist]
#2011584
02/14/16 03:08 AM
02/14/16 03:08 AM
Posts: 792 Earth
Rob C
Earth
That is my favorite chamber. I don't care for that closed chamber deal they have.
I don't know why every one gets all spun out on that chamber. It SHOULD make more HP than the closed one.
I'm not sure why they milled off the upper row of head bolts.
EDIT: do not mill the chamber down to close it. That is a sure HP killer.. And it makes the head weak. Not going to argue since going fast and making some really good power numbers with the W2 has been done since its birth, but I have to ask about the dislike of closed chambers. Would that be for the W2 head only? And you state it should make more power. Applies to W2 head only? Why is milling the W2 chamber down bad for HP?
