OK - I know, it's a ford 9", but it's what all of our crew uses, so I went with a 9" so we can all share gears, etc.
I have a VERY VERY long driveshaft, so I went with a 4" chrome moly driveshaft and 1350 u-joints, and I am at the bench trying to install a STRANGE U1603 yoke, I have the spacer kit STR-N-1918 - it has two spacers in it.
I was assuming the spacers would take the place of the crush sleeve, but even with both spacers in, the pinion splines still protrude up past the nut face...
Do I still need the crush sleeve, then use the spacers to eliminate the protruding splines ?? If so, do the spacers go under the yoke at the spline or do they go in with the crush sleeve ??
Seems like there should be some instructions someplace... Also a note - been a while since I bought a yoke - I forgot they don't come with straps... argh !!!
Thanks in advance !!
