Bolting ring gear to sure grip in 8.25 #2007021
02/06/16 10:49 PM
02/06/16 10:49 PM
USA
JoesMopar Offline OP
USA
When you lay the ring gear on the sure grip to get ready to bolt it together, should it lay flat or does it need to be pulled together as it's bolted?
Mine does not want to just lay flat and seems like it's a very tight fit. This is my first time assembling one so I'm not sure.
Re: Bolting ring gear to sure grip in 8.25 [Re: JoesMopar] #2007038
02/06/16 11:10 PM
02/06/16 11:10 PM
You'd want it to lay flat & way back I read something about "stoning" the ring gear with a fine whetstone like you sharpen knives with on the inner ID opening like you are chamfering it. I'd go real easy & definitely wait for others or the Doc to chime in
Re: Bolting ring gear to sure grip in 8.25 [Re: JoesMopar] #2007176
02/07/16 02:15 AM
02/07/16 02:15 AM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
I have not done an 8 1/4 setup but did have the same issue when setting up a Dana recently. Put the ring gear in the oven for a bit and just get it warm. It'll grow a bit and drop right on the carrier. If you think the wife will freak out, I hear a bucket of hot water will do the trick as well. Good Luck! up
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Bolting ring gear to sure grip in 8.25 [Re: MadMopars] #2007303
02/07/16 01:21 PM
02/07/16 01:21 PM
USA
USA
Thanks, I didn't even think of that.
Re: Bolting ring gear to sure grip in 8.25 [Re: JoesMopar] #2007371
02/07/16 02:43 PM
02/07/16 02:43 PM
CA
crackedback Online content
crackedback  Online Content
CA
Carrier in the freezer works as well.
Re: Bolting ring gear to sure grip in 8.25 [Re: crackedback] #2007377
02/07/16 02:53 PM
02/07/16 02:53 PM
I'd slightly stone the gear/freeze the carrier/heat the gear!
Re: Bolting ring gear to sure grip in 8.25 [Re: RapidRobert] #2007628
02/07/16 11:25 PM
02/07/16 11:25 PM
USA
USA
Sounds like I'm going to have to do a combination of everything...
I didn't know if this was a common problem or not when installing the gear into the carrier.
Re: Bolting ring gear to sure grip in 8.25 [Re: JoesMopar] #2007759
02/08/16 02:27 AM
02/08/16 02:27 AM
The stoning might not be the final word on achieving fitment but I think it is important for it to remove very minor machining and handling imperfections that might keep it from being dead on concentric & only takes several minutes. Let us know how the installation goes
Re: Bolting ring gear to sure grip in 8.25 [Re: RapidRobert] #2007765
02/08/16 02:34 AM
02/08/16 02:34 AM
USA
USA
Will do. I set it on the carrier just to see how everything would line up and noticed the fitment issue, but I'm planning on actually doing the work next weekend.
Re: Bolting ring gear to sure grip in 8.25 [Re: JoesMopar] #2009062
02/10/16 02:50 AM
02/10/16 02:50 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Couple years ago did my 2000 Dak and per the FSM use either a heat lamp or hot water. Do not exceed 300*F on the ring gear. I don't believe it's a consideration but it also says not to use a torch.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: Bolting ring gear to sure grip in 8.25 [Re: R70RUNNER] #2009933
02/11/16 04:48 PM
02/11/16 04:48 PM
dogdays Offline
dogdays  Offline
Blazin' Bob, you have the wrong idea about stoning. The stoning is done to the flat back of the ring gear in case there are any high spots from the bolt holes.
You might want to chamfer the id but ever so slightly and I don't believe that will do anything to concentricity.
Keep in mind that every ring and pinion is installed in a machine at the factory and "run in" using an abrasive slurry. So, however the gearset came off the machine is how it's going to run best.
Having a fun Winter?
R.
Re: Bolting ring gear to sure grip in 8.25 [Re: dogdays] #2010048
02/11/16 07:51 PM
02/11/16 07:51 PM
Oh OK yeah I had just assumed (incorrectly) that it helped fitment/concentricity. Not a good winter, too much thinking not enough action
Re: Bolting ring gear to sure grip in 8.25 [Re: RapidRobert] #2011437
02/13/16 11:32 PM
02/13/16 11:32 PM
USA
USA
Well putting the carrier in the freezer over night and the ring gear in the oven @ 150 deg for ~ an hour this morning did the trick.
Thanks again thumbs
Re: Bolting ring gear to sure grip in 8.25 [Re: JoesMopar] #2011448
02/13/16 11:42 PM
02/13/16 11:42 PM
ky.
K
kenworth_goose Offline
K
ky.
I prefer to set the ring gear face down on some wood blocks and hit the carrier with a hammer with a piece of wood between. Works good with no damage.
