Hydraulic roller cams, Big block, Front timing cover mods #2006615
02/06/16 11:33 AM
02/06/16 11:33 AM
Finally a HUSKER again
Moparnut426 Offline OP
Does anyone know what mods are needed if any for the cam button in a big block. I bought a mancini racing cam button and a mancini racing front cover, Its thicker than OE, but I still think its pretty flimsy. Don't want to take away from the OE look or Id run an aluminum cover.
Re: Hydraulic roller cams, Big block, Front timing cover mods [Re: Moparnut426] #2006618
02/06/16 11:45 AM
02/06/16 11:45 AM
crabman173
crabman173
Milodon front cover is thick enough reasonable $$ stock look Marsh has them in stock--use it and then when you put waterpump on observe the gap between cover and pump--usually not much--JB weld valve spring shim in the gap and you are done--or don't--usually gap is very slight-
Re: Hydraulic roller cams, Big block, Front timing cover mods [Re: ] #2006623
02/06/16 11:56 AM
02/06/16 11:56 AM
GREAT!!
Thanks...
