Re: Water pump driving me nuts.
[Re: RoyceFlo73]
#200603
01/21/09 11:14 PM
01/21/09 11:14 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
You can...but you *may* have to also change your timing cover to the 70-up style as well. Might be a good idea anyway as this is the most common setup.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: OzHemi]
#200607
01/22/09 12:06 AM
01/22/09 12:06 AM
RapidRobert
you got to angle the light just right & it's actually easier on the pass side when using 273 cover(pass marks) & later WP(pass hose) as you dont have the battery hindering you from getting the good angle whereas the other way with marks/hose on dr side it's alot more difficult.
[Re: RoyceFlo73]
#200609
01/22/09 12:21 AM
01/22/09 12:21 AM
RapidRobert
just be careful that you dont split the timing cover to block gasket seal when you R&R the pump. Mock everything up with a wp gasket w no sealer & lightly snug the bolts & you'll see how you need to space the crank/wp/alt pulleys till they all 3 line up then take em off add gasket sealer & bolt everything up for good.
[Re: Andrewh]
#200611
01/22/09 01:16 AM
01/22/09 01:16 AM
Posts: 374 CONNECTICUT
RoyceFlo73
CONNECTICUT
I like that idea more. Keeps it simple. I'll get new brackets, and pulleys from a late model 318 or something. Then just swap all of it. This engine swap seems like its always something else. I hope its worth it over the old leaning tower of power /6. I have 1 more thing to work out and im done. When i turn the wheels fully to one side or the other, i hear a loud squealing, sounds like a belt. Also, the corresponding side rises about 1 inch. (i.e. if i turn left, the left front picks up about 1 inch), i think i have to readjust the ride height.
[Re: RoyceFlo73]
#200612
01/22/09 07:49 AM
01/22/09 07:49 AM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
The squeal is the PS belt pump because its at the locks.The front end rising is normal.Its the tires moving.More pronounced on a short arm long arm car than a front wheel drive car.You can adjust the front end either up or down and it will still do it.Rocky
Chrysler Firepower
[Re: therocks]
#200613
01/22/09 10:51 AM
01/22/09 10:51 AM
Posts: 15,487 Florida
scratchnfotraction
could have just went to a rad shop and have the bottom outlet moved to the other side or have another bottom tank solderd on with the oulet were you want it I have done this before and was about 40 bucks or so same as you,wanting to used stuff I had that did not fit correctly even had it swaped back one time also I have cut up hose and used ellbows from my buddy that is an electicion that was the same size as the rad hose and run it under the rad area to get to the other side to hook up run long tubes as well on mud trucks with the rad moved to the back of the bed with elect fans for cooling added lots of cooling and used elctical pipe and a few cut up hoses but in a pinch you can do it the way you have
[Re: snuggles]
#200616
01/22/09 04:32 PM
01/22/09 04:32 PM
Posts: 2,826 NY usa
540challenger
NY usa
My memory is not always the best... Is a 273 a cast or forged crank motor? I think it could make a slight difference if its forged as opposed to cast in swapping pulleys etc. I did the swap on a forged crank 340 and used parts off a 71 318(last year forged crank I think and newer style pump) motor and went together nicely.
The early 273 were forged units i think the lates did switch to cast but they were all internally balanced. The balancer might be a problem, as you need to have the correct timing cover per blancer also the pattern for the crank pully changed but not a big deal by ovaling one hole it works. watch out of early 273 crnaks when running an automatic as they need a special convertor due to the smaller register in the crank.
