What are the bearing bores? No such thing as 48 or 59 bearing size. I have had several different bearing arrangements with 48 degree. There have been a few for 59.
What is the lifter bore spacing? 1.625 is common for 48. And 1.875 is stock 59.
The hurdle in making a camshaft with oil pump gear. Loose the gear and go external oil pump and front distributor solves problem. Order a spool and get your cam ground.
Leon,
I'll measure the block when it arrives. He didn't know. What does a guy have to do about a intake? I have w5's and a Indy intake. Can a guy mill enough off a standard deck Intake to make it work or what should a guy do?
Almost .500" has to be cut between intake and head. Easier to use a w8 intake. Port match and slot bolt holes.
If you plug and change to 48° you will have to cut the heads and intake for pushrod clearance.
Personally, I would keep shopping and find parts that mate.
