It fits...barely: car is complete and ready for dyno
#2002045
01/30/16 05:36 PM
01/30/16 05:36 PM
Posts: 698 Alberta Canada
Edge
Alberta Canada
Decided to pull the B1 and go forward with the hemi, rack has to repositioned and new fuel tank built but progress is being made, apsects of the build have gone beyond my skills now and the fabricator working on the car is doing great work I will post progress pictures if there is interest
76 Duster
work in progress
Re: It fits...barely
[Re: DaytonaTurbo]
#2002071
01/30/16 06:04 PM
01/30/16 06:04 PM
Edge
Alberta Canada
Mid plate has been milled to clear right bank and started mounted to mid plate
76 Duster
work in progress
[Re: sgcuda]
#2002087
01/30/16 06:23 PM
01/30/16 06:23 PM
Edge
Alberta Canada
Just a plenum going on top of the manifold so one centrifugal blower. Yeah its really a tight squeeze, just glad it fits
76 Duster
work in progress
[Re: SpareParts]
#2002193
01/30/16 08:49 PM
01/30/16 08:49 PM
Edge
Alberta Canada
Very cool. Can we see more of the car? Do you have a class in mind? Not the most recent pic but what I have on the computer, have posted progress pics of the car in the past but the engine switch is the most recent update
76 Duster
work in progress
[Re: Edge]
#2002202
01/30/16 08:55 PM
01/30/16 08:55 PM
Edge
Alberta Canada
More recent with the B1 engine that I am likely selling
76 Duster
work in progress
[Re: Edge]
#2003902
02/02/16 01:03 AM
02/02/16 01:03 AM
Posts: 474 Alberta, Canada
451Guy
Alberta, Canada
Hopefully when you are done there will still be some cement on the starting line at Castrol... Looking forward to seeing another kick butt mopar at our track!
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T Best ET 11.39 @ 118.11
[Re: Edge]
#2004016
02/02/16 10:45 AM
02/02/16 10:45 AM
Posts: 12,591 Great Neck,LI,new york
hemi-itis
That is NOT a stock block,,,,,,wonder if it's a water block,,,,,,,
[Re: hemi-itis]
#2004491
02/02/16 11:57 PM
02/02/16 11:57 PM
Edge
Alberta Canada
That is NOT a stock block,,,,,,wonder if it's a water block,,,,,,, Block is solid billet BAE block (no water passages) same with the heads. Only really interested in getting this project running and at the track hopefully this summer at this stage no ET target in mind would just like to have it go point a to b as a start.
76 Duster
work in progress
[Re: 72sat]
#2004500
02/03/16 12:08 AM
02/03/16 12:08 AM
Edge
Alberta Canada
The heads will only work on hemi block ( differnt head stud configuration than ) as well much larger head stud diameter.
76 Duster
work in progress
[Re: 72sat]
#2004967
02/03/16 06:04 PM
02/03/16 06:04 PM
Posts: 1,845 Tampa
DusterDave
Tampa
nice ride. this brings up a QQQQQ I've been thinking about. will BAE heads fit on a factory 440 block? Even if those heads could be made to fit, that stock 440 block would be reduced to shrapnel about 1 second into the run. LOL
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: Edge]
#2005014
02/03/16 08:11 PM
02/03/16 08:11 PM
Thumperdart
State of confusion
Mid plate has been milled to clear right bank and started mounted to mid plate Just plain mean looking.........good luck man.....
