Sand Blasting and Painting Fasteners - What Now?
#200010
01/21/09 03:17 PM
01/21/09 03:17 PM
Posts: 1,075 United States
STLDuster
United States
I am working on sand blasting a bunch of fasteners (nuts, bolts, and washers) for my car. I have the fenders and front end taken apart for some body work. I have been sand blasting the fasteners at work and organizing them in baggies. Now I have a bunch of baggies of bare steel bolts sitting waiting for the next step. I used to spray them with the Rustoleum Primer and leave them until I was ready for paint and then paint all the parts at once. But I wanted to ask around and see what others do. Would you put them in a fixture and give them a good coat of self etching primer? For the people that are very particular, how do you deal with this situation?
"No great genius has ever existed without some touch of madness." - Aristotle
Re: Sand Blasting and Painting Fasteners - What Now?
[Re: STLDuster]
#200012
01/21/09 04:53 PM
01/21/09 04:53 PM
Posts: 5,902 Athens, Greece
Pyper70
Athens, Greece
Bolts are just like the body of the car, PPG Primer and DCC topcoat of body color or black...At least to me...
Don't do the whole chemical process of black oxide in case you are pondering that method. I did my 69's engine bay bolts. I wire wheeled them all, sand blasted them, cleaned them with lacquer thinner, blew them dry and started the chemical process. In 6 months they were rusting. All that work for nothing....Took off whatever I could and sandblasted again...blah blah blah, that whole method and sprayed PPG on em'. 7 years and still good as new.
Just remember to wrap electrical tape around the bolt you are installing so the paint doesnt crack when you go to mount it on.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: STLDuster]
#200013
01/21/09 04:55 PM
01/21/09 04:55 PM
Posts: 3,318 Southern Maryland
klunick
Southern Maryland
I just prime them and shoot them with Rusto as soon as I get done with them. That way I don't have to remember where they go as they go right back on the part. Some of the stuff out there will harden up on them and make them impossible to fit, i.e. never POR-15 a bolt or hole as your dimensions will change. The long and short of it is that most of these bolts didn't have anything on them for the past 40 years so any protection at all is a big ++.
67 Barracuda FB
69 Superbee
"Southern Maryland: If you want a good looking woman, you had better bring her with you"
