engine quest heads info needed #199948
01/21/09 01:23 PM
01/21/09 01:23 PM
RapidRobert Offline OP
Engine Quest "magnum RT" australian SB heads. How do these compare to MP magnum RT heads(both unported) any quality control issues? Your thought please & thank you for your time.
Re: engine quest heads info needed [Re: RapidRobert] #199949
01/21/09 02:19 PM
01/21/09 02:19 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
I have a set of the Engine Quest heads on my 408 small block. Made 425 HP right out of the box. So flow seems to be great and really nice looking castings and valve jobs. I used the RT heads on another build a 360, hard to compare power output, but my impression is the Engine
Quest heads are a better value.
Re: engine quest heads info needed [Re: 469runner] #199950
01/21/09 02:37 PM
01/21/09 02:37 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
check the hughes engines site
the "iron ram" heads are the enginequest 318's....
BTW, it sounds like the MP R/T heads are discontinued....
2017 Grand Cherokee Overland
Re: engine quest heads info needed [Re: patrick] #199951
01/21/09 03:51 PM
01/21/09 03:51 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
Got-em on my 390 stroker and they work great with a 2.02 intake and some extra porting!! TBF
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: engine quest heads info needed [Re: tpabayflyer] #199952
01/21/09 04:12 PM
01/21/09 04:12 PM
Alright you've convinced me, I'm going to give Ben Gorman a call & grab his last set.
Re: engine quest heads info needed [Re: 469runner] #199953
01/21/09 04:43 PM
01/21/09 04:43 PM
Northern Va
Mopar73340 Offline
Mopar73340  Offline
Northern Va
So you are saying your heads made 425 HP with the stock out of the box 1.92" intake valves? Just wondering as I'm currently building a 408 and have those heads with 2.02's. Thanks
Re: engine quest heads info needed [Re: Mopar73340] #199954
01/21/09 05:04 PM
01/21/09 05:04 PM
Newark,De
hemi471 Offline
hemi471  Offline
Newark,De
For the money they are hard to beat. I just had a set done by Ryan at Shady Dell. After a full port they flow 269@.600 intake and 201 exhaust.
Re: engine quest heads info needed [Re: RapidRobert] #199955
01/21/09 08:05 PM
01/21/09 08:05 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I'd like to see a set of the EQ heads first hand. My only experience is with the factory magnum R/T heads and they are not the best quality castings around but plenty of potential to make good HP. A friend off mine has run 9.80's with the magnum r/ts and others have gone quicker.
