SB to BB swap problem #1998986
01/26/16 01:38 PM
01/26/16 01:38 PM
Western Colorado High Desert
moparmarks Offline OP
Working on a 1977 W150. Swapped out the 360 for a 440. Have the motor and tranny siting in place. The tranny is not far enough back to line up with the mounting holes. Need about another inch. I had to use a ratchet strap to pull the tail of the tranny over and now the pass side motor mount has pressure pulling it back. Been a while since I've done this swap and don't remember having this problem. What am I doing wrong?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: SB to BB swap problem [Re: moparmarks] #1998993
01/26/16 01:47 PM
01/26/16 01:47 PM
,Pa.
68dodge Offline
68dodge  Offline
,Pa.
Do you have the 440 motor mounts? Looks like the small block motor mounts. Both of my motor mounts are straight without the bend. Now if its a 4x4 your mounts are right, but they may need to be move forward on the block.
Re: SB to BB swap problem [Re: moparmarks] #1999000
01/26/16 02:00 PM
01/26/16 02:00 PM
All the books show the same insulators for SB and BB. I have the correct BB 4wd brackets and they only go on the back side of the ears.
72-4 4wd and 72-80 2wd use the straight brackets. 75-78 4wd use the offset brackets shown. All SB use the straight brackets but SB brackets won't bolt up to a BB.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: SB to BB swap problem [Re: moparmarks] #1999019
01/26/16 02:47 PM
01/26/16 02:47 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
That right rubber mount won't last very long with that much stretch. Are these brackets new, or are they old used items that have been repainted? If they are new, I wonder if someone bent them incorrectly. All the big blocks I remember had the brackets on the front side of the block ears, but then again, its been a long time. It also seems to me that the studs on the rubber mounts are off set, can you gain the difference you need by turning or flipping the rubber mounts?
Moving the brackets to the front of the ear will give you the difference you need. I'd probably put a spacer between the bracket and the rear ear, or see if I could open up the bracket to fit better (likely I'd do both). I Believe those brackets are squished together or improperly bent, or the studs in the rubber piece is not oriented correctly. Gene
Re: SB to BB swap problem [Re: moparmarks] #1999077
01/26/16 04:12 PM
01/26/16 04:12 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
There should be two sets of holes in the engine crossmember for the insulator stud to set in. One position is for a big block and the other is for a small block. You can seat everything in the small block holes but it results in the motor being "cocked" and the tranny mount not lining up.
Re: SB to BB swap problem [Re: moparmarks] #1999135
01/26/16 05:36 PM
01/26/16 05:36 PM
They are original mounting brackets.
I've never seen brackets mounted on the front side of the ears and I've done a lot of big blocks over the years.
No offset in the studs for that direction.
There are only one set of holes in the cross member and they are as far back as possible.
The drivers side is setting correct. Just the pass side is being stretched.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: SB to BB swap problem [Re: moparmarks] #1999147
01/26/16 06:07 PM
01/26/16 06:07 PM
Ok I did some measuring on the pass mount. The insulator is being pulled about 1/2" back. To mount the bracket on the front of the ears I'd have to cut off 3/4" of the thick ear and about 3/8" of the lower thin one leaving 1/4" of thickness. That would straighten out the insulator. If I don't cut the ears mounting the bracket to the front face of the thick ear and using spacers on the two thin ears then the bracket would be to far forward. I shouldn't have to cut the ears to make this work.
Actually there is another set of slots in the cross member but they are much lower and way to far forward.
The brackets look good and undamaged. Compared them with two other sets that I have.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: SB to BB swap problem [Re: moparmarks] #1999163
01/26/16 06:33 PM
01/26/16 06:33 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
This is probably a dumb question but can the mounts be swapped from one side of the engine to the other?
Re: SB to BB swap problem [Re: moparmarks] #1999164
01/26/16 06:33 PM
01/26/16 06:33 PM
I took off the mount. I guess an option is to cut the holes larger in the cross member and the bracket. Would need about an 1/4" in each.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: SB to BB swap problem [Re: stumpy] #1999167
01/26/16 06:36 PM
01/26/16 06:36 PM
No, not a dumb question. There is a right and left mount. Drivers side has a hole for the oil pump pressure valve nut.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: SB to BB swap problem [Re: moparmarks] #1999180
01/26/16 07:02 PM
01/26/16 07:02 PM
scratchnfotraction Offline
if the pass side was straight and not offset would that correct the 1/2" off?
I thought a BB 4x4 had driver side offset and straight pass side mount.
have another look at what side of the block ears the mounts are on.
my 2x has them both on the front side of the ears.
in the 1 pic it looks like a straight bracket on the front of the ears would put the hole lined up and rubber biscut flat.
Re: SB to BB swap problem [Re: moparmarks] #1999224
01/26/16 07:58 PM
01/26/16 07:58 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What if you bolt the trans to the crossmember then see what is needed to make the motor mounts to work? I would think the trans mounting would be the one thing that stays the same on the 4x4 swap. I'm used to going from slanties to small blocks or from 318 to 360s so I'm just trying to make helpful guesses. shruggy
Re: SB to BB swap problem [Re: scratchnfotraction] #1999263
01/26/16 08:35 PM
01/26/16 08:35 PM
If it was straight then it would be worse. Is offset back but needs to be more back.
The sets of brackets are a pair of offset or a pair of straight.
On SB the brackets go on front of the ears. BB on the back.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: SB to BB swap problem [Re: moparmarks] #1999265
01/26/16 08:39 PM
01/26/16 08:39 PM
Mounting BB brackets on the front of the ears would require cutting the ears. To me that is not an option.
Many thanks for your replies.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: SB to BB swap problem [Re: moparmarks] #2000950
01/29/16 02:45 AM
01/29/16 02:45 AM
Washoe Valley, NV
jrmopar1 Offline
jrmopar1  Offline
Washoe Valley, NV
You might need to flip around the trans crossmemeber. If the holes are offset at all you might have just put it in backwards by mistake and just flipping it around might fix your issues. Not sure if this will work but will be doing a big block swap on a 78 soon so I will have to look out for this issue also.
Re: SB to BB swap problem [Re: jrmopar1] #2000955
01/29/16 02:48 AM
01/29/16 02:48 AM
The tranny cross member is drill to only go in one way.
It is just the pass side motor mount that has a problem. Got the tranny to mount up and the drivers side motor mount is fine. Really weird.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: SB to BB swap problem [Re: moparmarks] #2001101
01/29/16 12:33 PM
01/29/16 12:33 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
Could the problem possibly be with the extension housing on the transmission? In other words, if your extension housing is off a newer transmission that is designed to mate up to a newer transfer case, the transmission mount location could have been changed.
The reason I'm asking this question is that I've been told the output shaft on the 203 transfer cases is a different length. If the output shaft is different, could the extension housing be different as well?
I have never heard of such a problem. If you find it is a problem of parts being incompatible, I'd appreciate if you would post what you find. I may have a big block swap in my future as well.
Re: SB to BB swap problem [Re: moparmarks] #2001113
01/29/16 12:54 PM
01/29/16 12:54 PM
The extension housing came off of this truck. The SB tranny had a fresh rebuild on it so we took all the guts and extension housing and put them in a BB 727 housing.
As I stated the tranny and drivers side mount all line up fine. Just the pass side mount is being stretched back. I've done a few BB swaps and have never had this problem. I've compared the pass bracket with others and don't see any difference. Can't find any damage to the frame from being in a wreck or anything. Funny thing is that I took this motor out of a 2wd truck a few years ago even though it is a 68 440 probably original from a C-body.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: SB to BB swap problem [Re: moparmarks] #2001682
01/30/16 01:43 AM
01/30/16 01:43 AM
ND
dodgedon Offline
dodgedon  Offline
ND
Its hard to tell in your picture, But are you missing a plate that goes between the trans extension and the cross member? It seems to me that the trans is bolted direct to a plate and the plate has the rubber mounts with the bolts going into the cross member. Does that make sense?? Your picture looks as if the bolt is going through the extension, a rubber biscuit, then the cross member... Is that correct? Maybe I can find a picture of what I'm trying to say.....
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: SB to BB swap problem [Re: moparmarks] #2001697
01/30/16 02:10 AM
01/30/16 02:10 AM
It didn't have a plate. Extension sits on thick washers then the rubber mounts. Same on the underside. Rubber mounts then thick washers and then the nuts. Should there be a plate?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
