'71 E-Body Proportioning valve with disc brakes #1989740
01/13/16 03:40 AM
01/13/16 03:40 AM
3
340clone Offline OP
340clone  Offline OP
Swapping to front factory discs on my '71 Challenger. The drum brake brass proportioning valve seems to be standard across the board. When a car had disc brakes a coupler was added (for front brakes) and sealed with a copper washer.
I have an old brass factory disc proportioning/metering valve (it's toast) that I plan to use for reference and parts. I unscrewed the coupler to find a spring inside, and I thought I might have heard something drop to the floor when I pulled the spring out. I did find a lot of hard crud inside the spring, which continued to fall out as I cleaned it up. Is there anything else in there that may have fallen out like a ball bearing or something?
I guess I'm wondering if I can add the spring and coupler (and any other necessary parts incl. metering valve) to my original drum brake valve and make that work with discs, or should I just scrap it and buy a new repro?
Thanks!
Re: '71 E-Body Proportioning valve with disc brakes [Re: 340clone] #1989806
01/13/16 12:25 PM
01/13/16 12:25 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Drum brakes didn't have a proportioning valve, what you have is just a distribution block. You need a real proportioning valve. There were a few different types that the factory used. I would try to find a factory valve and have it rebuilt.
Re: '71 E-Body Proportioning valve with disc brakes [Re: 71birdJ68] #1989848
01/13/16 01:30 PM
01/13/16 01:30 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
Here's mine that I just refinished
Re: '71 E-Body Proportioning valve with disc brakes [Re: 71birdJ68] #1989850
01/13/16 01:32 PM
01/13/16 01:32 PM
IN
ahy Offline
ahy  Offline
IN
If you are running front discs/rear drum there is a good chance you will have excess rear bias.
I'd keep the original drum brake setup... which is basically a "T" for the front and add a rear proportioning valve. The Wilwood valve is a good one. It can install neatly on the drivers side inside frame rail where the rear line runs.
If you are running a new master, it may not have a residual pressure valve for the rear brakes. A residual pressure valve can be added in the same spot you add the rear prop valve. Many consider this valve optional but Inline Tube, where I got most of my stuff, recommends it.
Re: '71 E-Body Proportioning valve with disc brakes [Re: shakerjoe] #1990030
01/13/16 05:33 PM
01/13/16 05:33 PM
3
340clone Offline OP
340clone  Offline OP
Looks great!
In the first photo, there is a brass coupler up top with a copper washer underneath. If you were unscrew that coupler there is a spring inside. Is that spring supposed hold a check ball or something? I am wondering what the function of that spring is?
