MY 6.4 hemi W/545 Trans, goes into limp mode at fwy speed #1989729
01/13/16 03:03 AM
01/13/16 03:03 AM
SO. CAL.
70blackfish Offline OP
SO. CAL.
I need to figure out why my truck goes into limp mode at fwy speed.
Re: MY 6.4 hemi W/545 Trans, goes into limp mode at fwy speed [Re: 70blackfish] #1989888
01/13/16 02:34 PM
01/13/16 02:34 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
engine or transmission limp mode?
Engine is high hide only
Trans is one gear only (usually)
Re: MY 6.4 hemi W/545 Trans, goes into limp mode at fwy speed [Re: 70blackfish] #1990406
01/14/16 02:39 AM
01/14/16 02:39 AM
SO. CAL.
SO. CAL.
code po443 poo38 poo58. any of these make engine go into limp mode, engines goes from 2100 rpm to idle, gas pedal does nothing, pull to side of the road cycle engine. gas pedal works. but does it again once i hit freeway speed in less than 5 min.
Re: MY 6.4 hemi W/545 Trans, goes into limp mode at fwy speed [Re: 70blackfish] #1990456
01/14/16 04:30 AM
01/14/16 04:30 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
Do you have one of those oil catch cans in the pcv hose? If so, look for an air leak in a hose, clamp or fitting. Had this issue on my srt8 challenger. It's scary when it happens on the freeway. Another Thing to check would be the carbon canister purge line from the intake, make sure there are no leaks there either. Can you post the freeze frame data?
Re: MY 6.4 hemi W/545 Trans, goes into limp mode at fwy speed [Re: 70blackfish] #1990912
01/14/16 09:37 PM
01/14/16 09:37 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Wow, this happened last week on my SRT-6.4, message in dash said something about throttle "something" and gas pedal did nothing and engine went to idle. After a few seconds it was ok, scary feeling. Definitely want to hear what you find.
Re: MY 6.4 hemi W/545 Trans, goes into limp mode at fwy speed [Re: 70blackfish] #1991595
01/15/16 11:19 PM
01/15/16 11:19 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
P0038-O2-SENSOR 1/2 HEATER CIRCUIT HIGH
P0058-O2-SENSOR 2/2 HEATER CIRCUIT HIGH
P0443-EVAP PURGE SOLENOID CIRCUIT
This is the one thing that really sucks about drive by wire. The computer is "seeing" a different amount of air (via the sensors) than what it expects for a given amount of throttle opening, so it says FU and goes into limp mode. I think the only way to figure this out is with the freeze frame data. Even the cheaper scan tools will give you freeze frame data now. Physically, I would look for vacuum leaks and chaffed wiring for the post cat O2 sensors (if you have them). I can get you the wiring and flowcharts if you want.
chart attached is for the p0038 code
Re: MY 6.4 hemi W/545 Trans, goes into limp mode at fwy speed [Re: 70blackfish] #1991656
01/16/16 12:37 AM
01/16/16 12:37 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Maybe mines the oil filler cap, just changed oil that day. I know you're talking to the other guy but I think you helped me on mine, I check it tomorrow.
Re: MY 6.4 hemi W/545 Trans, goes into limp mode at fwy speed [Re: 70blackfish] #1991673
01/16/16 12:53 AM
01/16/16 12:53 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Dead pedal limp mode.
Mopar to the bone!!!
Re: MY 6.4 hemi W/545 Trans, goes into limp mode at fwy speed [Re: 70blackfish] #1992181
01/16/16 08:43 PM
01/16/16 08:43 PM
SO. CAL.
SO. CAL.
yes dead pedal limp mode. it has only two o2 sensors and no cat converters..
Re: MY 6.4 hemi W/545 Trans, goes into limp mode at fwy speed [Re: 70blackfish] #1992325
01/17/16 12:22 AM
01/17/16 12:22 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
What engine management system do you have? HotWire?
Re: MY 6.4 hemi W/545 Trans, goes into limp mode at fwy speed [Re: 70blackfish] #1992402
01/17/16 03:18 AM
01/17/16 03:18 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
If whoever supplied the harness and tune disabled the secondary o2 sensors, then you need to go after the evap code first. Again, the code could be a result of a wiring issue or a vacuum leak.
Do you have a carbon canister and a purge solenoid or was that removed from the harness too?
Re: MY 6.4 hemi W/545 Trans, goes into limp mode at fwy speed [Re: 70blackfish] #2010587
02/12/16 05:56 PM
02/12/16 05:56 PM
SO. CAL.
SO. CAL.
they tell me, not and easy fix. still working on it.......
Re: MY 6.4 hemi W/545 Trans, goes into limp mode at fwy speed [Re: ntstlgl1970] #2011075
02/13/16 02:18 PM
02/13/16 02:18 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
A vacum leak will not cause any of these codes as these are all electrical codes. First thing I do when I have a few codes that are electrical related is look at the wire diaghram and see if any of the circuits are related and tied in to each other anywhere including grounds. Ron
