Corner of the hood stays up! #1987456
01/10/16 12:06 PM
01/10/16 12:06 PM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
Hi everyone!
When I close the hood on my '72 Satellite. The driver side corner at the windshield stays up about one inch, and I have to press it down by hand. If I pull up on that corner, it stays up again. I removed the spring to see if it has stretched, but it appears to be fine. I also tried different adjustments, but now I am completely stumped! Any ideas would be appreciated.
Re: Corner of the hood stays up! [Re: Hooligan] #1987477
01/10/16 12:48 PM
01/10/16 12:48 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Common issue with worn out hood hinges...The pivot points are loose...RestoRick rebuilds hood hinges to better than new standards if you don't have another set...
Re: Corner of the hood stays up! [Re: Hooligan] #1987495
01/10/16 01:08 PM
01/10/16 01:08 PM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
Cool thanx! I just removed both hinges and freed them of their springs. The pesky driver side hinge was sloppy and the passenger side was tight.
I'll check out Resto Rick next. Everyone can relax now and take the rest of the day off. Oh wait! We have other members who need help... nevermind :-(
Re: Corner of the hood stays up! [Re: Hooligan] #1987879
01/10/16 08:18 PM
01/10/16 08:18 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I have the EXACT same problem with my '72 Duster. For awhile I could just shut the hood and push that corner down, but now it pops back up after I drive a couple miles.
Re: Corner of the hood stays up! [Re: Hooligan] #1988165
01/11/16 01:41 AM
01/11/16 01:41 AM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
Read the bottom paragraph in the link. Helped me get mine situated. Good luck. up
Hood Adjustment by Resto Rick
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
