Did Mopar ever use a tapered,,,,, #198498
01/19/09 09:03 PM
01/19/09 09:03 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
seat spark plug in any of the big block's, a friend of mine has a 1977 Motorhome that he swear's has taper seat plug's,,need to verify before I tell him he has lost it.
Re: Did Mopar ever use a tapered,,,,, [Re: dartman366] #198499
01/19/09 09:10 PM
01/19/09 09:10 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
yes, pulled a 440-3 out of a van that had 452 heads with sb chevy style tapered plugs and also found the same thing in a full size '73 camper with 213 heads. Also could be found on highway patrol cars.
Re: Did Mopar ever use a tapered,,,,, [Re: dartman366] #198500
01/19/09 09:13 PM
01/19/09 09:13 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Could be, I had a set of mopar small block heads with 18 mm plug threads, like an old ford.
Re: Did Mopar ever use a tapered,,,,, [Re: buildanother] #198501
01/19/09 09:31 PM
01/19/09 09:31 PM
southern in.
72sebring Offline
72sebring  Offline
southern in.
sure my 440 is from a 72 motor home im still running the peanut head as its called. no problrms except a little clearence problems with 1 plug and the header.
Re: Did Mopar ever use a tapered,,,,, [Re: 446acuda] #198502
01/19/09 09:37 PM
01/19/09 09:37 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
well, that's a new one on me,, Thank's Guy's it's a good thing I didn't make a wager on that.
