Aftermarket oil pans and big block A-bodies #198136
01/19/09 02:52 PM
01/19/09 02:52 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
Are there any aftermarket extra capacity oil pans that will fit on big block A-bodies? I know the stock pans like the 187 pan are notched for clearance so I didn't know if any aftermarket pans like Milodon would have clearance issues.
Re: Aftermarket oil pans and big block A-bodies [Re: 1970RT] #198137
01/19/09 04:28 PM
01/19/09 04:28 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I've used both the Milodon and the Moroso with no problems.I prefer the Moroso.
Nautilus Racing-
Re: Aftermarket oil pans and big block A-bodies [Re: Chris2581] #198138
01/19/09 07:12 PM
01/19/09 07:12 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
As an owner of a BB A-body and one who wiped out a deep sump Milodon pan, I strongly suggest you use a #187 pan (with or w/o a homemade baffle).
Re: Aftermarket oil pans and big block A-bodies [Re: Kudakidd] #198139
01/19/09 08:42 PM
01/19/09 08:42 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
We use the Moroso pan on my sons 400 Dart and it has nice clearence from the road. And it has never hit anything. Ron
Re: Aftermarket oil pans and big block A-bodies [Re: 383man] #198140
01/19/09 09:49 PM
01/19/09 09:49 PM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
I'm using a 402 pan on my duster. It came with front and rear baffles. fits nice, no suspension interference. If it matters, used DC K member for engine install and its an original 340 car.
