Ball Joints/Tie Rod Ends #198102
01/19/09 02:24 PM
01/19/09 02:24 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Best why to tell when greasing the joints enough is enough.
Grandma always said I had "hands of gold"!
Re: Ball Joints/Tie Rod Ends [Re: CHRGR69] #198103
01/19/09 02:52 PM
01/19/09 02:52 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I usually just do it until I see the boots start to puff up a little.
Re: Ball Joints/Tie Rod Ends [Re: OzHemi] #198104
01/19/09 04:26 PM
01/19/09 04:26 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
I still make a mess though............even when I try paying attention! They will start seeping when you see them puff out, just try to stop before I usually do!
Re: Ball Joints/Tie Rod Ends [Re: 4BBodies] #198105
01/19/09 05:05 PM
01/19/09 05:05 PM
I like to smear some grease on the ball(as much of it as I can cover) by hand & move the ball all around thru its travel to coat all of it then add the boot then pump grease in the zerk.
Re: Ball Joints/Tie Rod Ends [Re: RapidRobert] #198106
01/19/09 08:10 PM
01/19/09 08:10 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
That will be the exact moment in time when you get the worst itch on the tip of your nose..
Re: Ball Joints/Tie Rod Ends [Re: OzHemi] #198107
01/19/09 08:45 PM
01/19/09 08:45 PM
It's all in the timing
