Question about bronze gears
#197929
01/19/09 11:25 AM
01/19/09 11:25 AM
Are the BB bronze distributor gears the same dimensionally as the stock steel(iron?) ones? Or do roller cams use a different size as well as material? Market research on my part. TIA.
Re: Question about bronze gears
#197930
01/19/09 11:53 AM
01/19/09 11:53 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I would think they are the same but I dont have a pair in the shop to measure. I would think the factory would make them the same due to a cost factor, make everything the same is easy ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#197931
01/19/09 12:02 PM
01/19/09 12:02 PM
I would think so, too, but just thought I'd check on here. Thanks!
#197932
01/19/09 01:55 PM
01/19/09 01:55 PM
Posts: 1,490 smyrna,tn
draginmopars
smyrna,tn
I have found that the drives are the same, that only the shaft is longer on my mag drive (on right)
Ha-Ha Racin Havin Fun 101
Howard
68 "Cummins" Satellite 70 W-2 449 "More Door" Dart 70 340 Dart Swinger, 4spd 71 360 Dart Swinger 72 540/ 518 Dart Swinger 73 airwolf 446/a-500 Cuda 73 "Cummins" Crew cab-car hauler 84 446 Dodge Rampage (tube chassis) 92 CTD 11' flat bed 92 CTD club cab 07 Dodge Caliber
[Re: mac56]
#197935
01/20/09 02:13 AM
01/20/09 02:13 AM
Thanks for the confirmation, guys! If things pan out, you street guys wanting to run roller BBs will have a better(far more durable than bronze) part soon. One less thing to worry about going that route.
[Re: HPMike]
#197937
01/20/09 08:13 AM
01/20/09 08:13 AM
Posts: 2,175 Duloc
The Shadow
Duloc
Let me guess....
It will be made of high density plastic.
MB
I looked into making the composite gears last year but found the proper material was more than 10x the price of bronze. Maybe you have found something cheaper. I would love to get away from the bronze Good luck. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: HPMike]
#197938
01/21/09 12:00 PM
01/21/09 12:00 PM
If you mean the carbon ultra-poly material, yes, that's what I'm looking into. It costs more, but then, it doesn't wear out nearly as quick(if ever). Haven't been serious about it for awhile. Last time I was, I couldn't locate a raw material source. I admittedly didn't look very hard. Seems to work well for the ford,chevys,pontiacs,buicks,etc that they're otherwise available for. I realize SB mopars can just use the factory Magnum part for the gear in that application. I'm just surprised noone else has filled the niche already.
[Re: The Shadow]
#197940
01/22/09 01:41 AM
01/22/09 01:41 AM
I got a piece form a place called poly-tech in North Carolina. It was about $50 for a 2" piece to make a prototype gear and that was a deal because he had an off cut laying around.
I'll check that out! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: VanishPt]
#197942
01/22/09 08:34 AM
01/22/09 08:34 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
very soon? how very soon?
is this soon as in this year?
