Re: Hemi...best street driver configuration from 4.5" bore
[Re: moparmatthews]
#1976087
12/25/15 01:26 PM
12/25/15 01:26 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
How about sell the crank, rods, heads, cam and rocker arms, and buy a complete stroker kit, massaged quality aluminum heads, hydraulic roller cam and quality rocker arms? Put a nice EFI set-up on it, and tell the well-regarded builder you want it tuned to be a smooth running, pump-gas burning street motor that is like Dr Jekyll and Mr Hyde.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: moparmatthews]
#1976104
12/25/15 02:00 PM
12/25/15 02:00 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I was where you are now a few years ago, I went with the 4.5 stroke crank, and got a killer deal on a set of the MP 9.5 to 1 pistons, I wish I had more compression now, there is a set of 12 to 1 MP pistons on ebay now. I started with stock rockers, went with StageV rollers, hydraulic roller does not work easy in a Hemi, the lifters are too tall. I went with a mech. roller with pushrod oiling. Those new heads that flow like 400 out of the box seem like the ticket. I would love to have those heads and fuel injection....Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: moparmatthews]
#1976238
12/25/15 05:26 PM
12/25/15 05:26 PM
Posts: 43,237 Bend,OR USA
Cab_Burge
The 426 street Hemi motors can use more compresion on todays pump gas with no problems than any other motor out there with iron heads if I was you and money wasn't a real big problem I would sell the other parts and buy a 4.25 stroke crank with BB Chevy journals, a set of BB Chevy type 7.100 long H beam steel rods and have a set of pistons made that would have a true 10.5 to1 compression ratio. I built a local customer and freind a motor just like that with a custom ground hydraulic roller cam and he loves it, it has iron heads and a dual plane single four barrel intake off of a crate motor with a Holley 850 double pumper, it is in 1968 Charger with a Dana 60 with 3.73 gear and short(28 inch tall) and a 727, full interior not cut up. It is a hoot to drive, responsive as all get out IHTHs EDITED. The BB chevy rods and the 4.25 stroke crank won't require any grinding on the cylinder walls to clear the rods and crankshaft If you where using the same stroke crank with Mopar rod journals and mopar stock type rods you will have to grind some on the cylinder walls and also on the oil pump pickup boss to prevent them hitting I've built a bunch of Mopar 426 Hemi and B and RB wedge motors with the BB Chevy journals and 4.25 stroke, they work great in these motors
[Re: moparmatthews]
#1976549
12/26/15 02:33 PM
12/26/15 02:33 PM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
Like everyone else says, put in a stroker crank. You will also need a lot more cam. That Mr. Six Pack cam will run out of steam way to early with a big motor. Hemis like to rev. Don't hold it back with a 5000 rpm cam.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#1976740
12/26/15 08:54 PM
12/26/15 08:54 PM
Posts: 10,144 A Red State
SNK-EYZ
A Red State
Like everyone else says, put in a stroker crank. You will also need a lot more cam. That Mr. Six Pack cam will run out of steam way to early with a big motor. Hemis like to rev. Don't hold it back with a 5000 rpm cam. I've been there and done that so I can completely relate. The torque from a stroker motor rocks, but too small of a cam and it will run out of air waaaay to soon. Depending on if you go with a flat tappet solid lifter cam or roller you can get a custom ground cam for your combination for starting at roughly $200. Obviously a roller cam will cost more.
[Re: moparmatthews]
#1976950
12/27/15 03:02 AM
12/27/15 03:02 AM
astjp2
Utah and Alaska
I went with the Go Big or Go Home attitude. Its all the same money to build a 426 as a 572....
[Re: Suregrip391]
#1976958
12/27/15 03:14 AM
12/27/15 03:14 AM
Posts: 52,972 Romeo MI
MR_P_BODY
It sounds as if you are just looking to use your 4.5" bore block in place of a stocker 4.250" bore block, not wanting any headaches associated with the build or needing any tuning afterwards, just a smooth running cruise night car type of engine that is street driven and not beat on. Is that right? Not a performance minded stroker in other words? Can you tell us your expectations for the car/engine? This is what I think he is looking to do.. just a cruiser that runs on the low octane... will never see the track and wants a low rpm engine... its not my cup of tea but it may be his... when I had my hemi it was years ago and it took a lot of tuning to keep it right... now days if I were you I would put injection on it
[Re: moparmatthews]
#1977082
12/27/15 01:51 PM
12/27/15 01:51 PM
Posts: 12,192 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The OP has clearly stated his goals, says he is a rookie, and has asked for advice.
Andy F has the best suggestions. And, like Andy, I would also encourage the OP to find an experienced Hemi builder and follow his advice on how best to achieve his goals.
Master, again and still
[Re: moparmatthews]
#1977180
12/27/15 03:41 PM
12/27/15 03:41 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I agree that if you're new to the game, then getting your feet wet on a relatively expensive platform to build, like the gen 2 hemi, then having an experienced builder guide you through the process makes a lot of sense( or just have them build it for you). All that being said, the smallest thing I would build to make use of that 4.50 bore block would be a 540(4.5 bore x 4.25 stroke). If he already has the 426 top end and is just looking for a cruiser type build, I would just reuse it all. Clean up the heads, get a decent cam........ 600-650hp on pump gas should be a no brainer, or more...... Depending on just how mild the finished combo is.
[Re: WO23Coronet]
#1977340
12/27/15 07:37 PM
12/27/15 07:37 PM
MR_P_BODY
What exactly are you going for? HP/et expectations? Unless you specify you'll have recommendations from a stock 426 to a 1000 hp monster. To me I'm guessing you want something like quickd100 has, streetable, big cube, low RPM deal (even still his puts out 800 hp in a very mild package) He does state it...in his opening ... last sentence..smooth running street engine
[Re: moparmatthews]
#1977404
12/27/15 09:16 PM
12/27/15 09:16 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
a 480 hemi with that cam will be pretty smooth, very strong through t he RPM just not a real high RPM. If I was in his boat I would build what I have but run at least 10.5 compression since you got a hemi that is detonation resistant as well as the big bore allows you to get a little bit of quench. Something as complex as a gen II hemi you don't need to throw in more variables like stroking it when it is not needed. It is not like what he has is very valuable so he can not sell it to finance a stroker anyhow.
