'00 Durango- P1757 code revisited... #1976535
12/26/15 01:57 PM
12/26/15 01:57 PM
Buford, GA
I_bleed_MOPAR Offline OP
Buford, GA
So I dropped the pan to check and see if I had another problem before ordering parts for the governor (thanks again, HotRodDave & Ron up ). The pic is what I found stuck to the magnet. Fluid still clean and no other debris in pan. Looks like a retainer from a clutch pack. frown Anyone seen this and can confirm my suspicion?
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: '00 Durango- P1757 code revisited... [Re: I_bleed_MOPAR] #1976585
12/26/15 03:40 PM
12/26/15 03:40 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
Yup, from o/d section. Typically the snap ring for the direct clutches in the o/d unit breaks.
Re: '00 Durango- P1757 code revisited... [Re: I_bleed_MOPAR] #1976590
12/26/15 03:50 PM
12/26/15 03:50 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
What he said.
You can fix it without removing the trans, just the OD section and you will need a press of some sort and an intermediate shaft or spline alighnment tool. I have eye balled them to line em up but might take a couple tries to get it just right so it will go back on.
Re: '00 Durango- P1757 code revisited... [Re: I_bleed_MOPAR] #1976591
12/26/15 03:51 PM
12/26/15 03:51 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Thats one reason why I always replace em all with flat snap rings.
Re: '00 Durango- P1757 code revisited... [Re: HotRodDave] #1976593
12/26/15 03:55 PM
12/26/15 03:55 PM
Buford, GA
Buford, GA
Where can I get one of these flat snap rings, Dave?
Thanks, guys. thumbs
Tim
'71 Charger 383/727
