Re: Best alternative to a TruTrac
[Re: crash520]
#1977076
12/27/15 01:43 PM
12/27/15 01:43 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
LOL It is not a wheel bearing problem, there is NO support at the spline end of the axle with this type of carrier, the side gear will move around & lets the axle move.
[Re: crash520]
#1977396
12/27/15 09:03 PM
12/27/15 09:03 PM
Posts: 247 Brisbane Australia
crash520
Brisbane Australia
You are correct, there is nothing holding the axle in the center section, that wheel movement you see is the axle pivoting at the wheel bearing, the end float in that clip is set at 0.004" with a DTI, the bearing is tight in the housing, I am holding the wheel at 3 and 9, pushing with one hand pulling with the other, (just like you do on the front wheels to check for loose bearings).I can tighten the adjuster on the wheel bearing to no end float and still wobble the wheel. Futher to this, I swapped centers back to the factory open center (single spinner)used the same axles, same bearings, same set up only now Im using 0.008" axle end float, (ONLY THING I HAVE CHANGED IS THE DIFF CENTER, WHICH THE SIDE GEARS HAVE NO MOVEMENT GO STICK YOUR FINGER IN ONE IF YOU HAVE ONE LAYING AROUND) guess what,,,,,,,, noise is gone so those suggesting its the wheel bearing, think again.
[Re: crash520]
#1977449
12/27/15 10:19 PM
12/27/15 10:19 PM
crash520
Brisbane Australia
Screamin, Cass has been talking to Eaton on this, he has multiple video's showing the side movement and agree's there is a problem, he spoke to them at SEMA and all they are saying is, its in spec, regarding the side gear movement, Cass is still arguing this with Eaton, when I first raised it with Cass, about 12-18 months after I purchased it, and about 2000Miles on it, I had been chasing the rattle from new, thinking it was exhaust, tailshaft, on and on you name it, then one day I just grabbed the wheel and wobbled it to find out it was as indicated, I knew the axle spine fitted well, figured I best just pull the third member for now and woek on the noise, now, at that point I reached out to Cass, I didnt buy it directly from him, a mate did, anyway Cass is an awesome guy as well all know, Eaton sent out a new replacement at no charge, again I praise them for this service as technically it was out of warranty, both Cass and Eaton went above and beyond, something rare in my country. Yes I can poke an axle into the bare Trutrac center and it will move side to side,,, lots. When compared to mopar single spinners or cone/clutch, their side gears have no movement. Im at a lose for now, I will pull one of them apart to see if there is a reason why they are like that, maybe they need to be that loose for whatever reason, the other thing is I have a 0 offset on my wheels maybe if I had more wheel out (less backspace) thus loading the axle more it would make no noise, who knows,
[Re: crash520]
#1977609
12/28/15 01:01 AM
12/28/15 01:01 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
anyway Cass is an awesome guy as well all know 100%... I got my 9" center (with trutrac) and axles from Cass. (For the 9" diff in my Torana ) Sure is a shame though with all the issues on your's..
[Re: crash520]
#1978821
12/29/15 08:07 PM
12/29/15 08:07 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I'll offer that my experience with the Detroit locker has been just fine. Been running one in my 8.75 for 3 years now. People say they are noisy; I rarely hear a thing. People say they clunk in & out... I occasionally feel it "shift" or "unlock" when slowing while going around a corner, but as long as you know what it is... no big deal. Durability wise: its been bombproof. The only issue I have with it is that as you get on and off the gas, it will want to push the car left or right as it unlocks and locks. This is no big deal, until you chop the throttle a couple of times at the top end of the drag strip at 115 mph. Then, it will get your attention. As I look to do more racing over the next few years, I will likely be going to a spool partly because of that issue. If it weren't for the racing thing, I'd be happy as a could be with my locker.
[Re: crash520]
#1978896
12/29/15 09:46 PM
12/29/15 09:46 PM
Posts: 5,777 ohio
ruderunner
ohio
As someone whos logged at least 100000 miles in detroit equippped trucks, I love em.
Spendy but bulletproof and always there since there's not really anything to wear out like clutches.
Angry white pureblood male
[Re: crash520]
#1979377
12/30/15 04:02 PM
12/30/15 04:02 PM
Posts: 74,976 U.S.S.A.
JohnRR
U.S.S.A.
Stanton, good question! Pretty much what I asked in my first post, I guess my options are, Detroit locker, cone style, clutch pack style and spool, are there any others to throw in the mix? When I track it, it will have slicks and I'm pushing for around 500 RWHP, we should hit 600 flywheel easily. 727 and not a transbrake. If you have that much power, and slicks, you should cross ANY type of CONE type off your list or you'll be back in it again , CONE types are GARBAGE by design .
[Re: StealthWedge67]
#1979735
12/30/15 11:24 PM
12/30/15 11:24 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I agree as I have been running a Detroit Locker in my 8-3/4 about 6 years. But I have never had any problems of it making my car go to one side or the other. After I go through the traps I just lift the throttle and it slows down straight as an arrow even when braking or downshifting.
