Best alternative to a TruTrac
#1975902
12/24/15 11:07 PM
12/24/15 11:07 PM
Posts: 247 Brisbane Australia
crash520
Brisbane Australia
Guys, I have an 83/4 with a TruTrac that Im not happy with due to the noise it makes whilst coasting and cruising nor the way the rear wheels wobble like a loose front wheel bearing. Im looking for suggestions to a viable alternative that will give me simialr performance. Car is a E Body, 408/727 (solid roller cam, W2 closed chamber heads, FAST EFI, 11.5:1 CR and so on, makes around 600 at the flywheel), its mostly a street driven beast with the occasional run down the strip or round a circuit. I dont want to go spool and Im thinking a cone or clutch type LSD may or maynot work with the HP, a Locker would be probably ok but is noisy round corners, any suggestions??? I love the way the TruTrac works as such and that its maintenance free and so on, just hate the noise, people that ride with me the first time look at me like the back end of the car is about to fall out!!!
Re: Best alternative to a TruTrac
[Re: ahy]
#1975930
12/25/15 12:21 AM
12/25/15 12:21 AM
Posts: 2,826 NY usa
540challenger
NY usa
I have a trutrac in my 8 3/4 ebody and I don't have any of your problems. Good luck I hope Eaton makes it right.
[Re: crash520]
#1975956
12/25/15 01:21 AM
12/25/15 01:21 AM
crash520
Brisbane Australia
Stanton, granted there is some tire flex from me pulling and pushing, here is a vid of the side gear when I pulled the centre out. It has also started marking the spline of the axles about half way along the spline giving me cause for concern as for leading to a weakening of the axle, as for the noise, under load it makes no noise, on coast or through a parking lot, it sounds like a jam can full of oil with a half doz lug nuts being rolled along, and no amount of speaker volume hides it!!!! [img]http://i3.photobucket.com/albums/y84/crash520/th_IMG_0137.mp4[/img]
[Re: RJS]
#1976245
12/25/15 05:38 PM
12/25/15 05:38 PM
Posts: 704 USA
rftroy
USA
From the movement you have, I'm assuming you don't have conrad bearings (Green bearings), but have the stock tapered roller bearings. I don't see the differential thrust block in your video. And, that side gear movement is normal. When under torque loads, the elements in the TruTrac 'find their own center' and the pinion gear loads keep the side gear centered. Dr. Diff's site tells you that you need to install the thrust block when using stock adjustable bearings. http://www.doctordiff.com/8-3-4-eaton-truetrac-differential.htmlThe thrust block should have been packed with your TruTrac. It looks like this: Once you get the thrust block in, you'll be good to go. If you didn't get it, call Eaton. They have pretty good customer service, and they'll get you one. Bob
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: crash520]
#1976255
12/25/15 05:59 PM
12/25/15 05:59 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
After watching the video, I don't see that as a differential issue at all. I see wheel bearing issues. I'd defer to Cass here, though.
[Re: crash520]
#1976306
12/25/15 08:18 PM
12/25/15 08:18 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Hey, I know your problem.....change to a Dana 60 and be done with it. Less headache and you would be on the track already...Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: crash520]
#1976327
12/25/15 09:22 PM
12/25/15 09:22 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I run a True Trac in my Imperial. Zero noise. That car is so quiet that I'd hear any noise the diff is making.
I hope they can get you straightened out.
[Re: crash520]
#1976356
12/25/15 10:50 PM
12/25/15 10:50 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
mine is doing the same thing, I had green bearings at 1st, then the tapered,it is a problem with the side gears.
[Re: crash520]
#1976547
12/26/15 02:25 PM
12/26/15 02:25 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
My friend had a TruTrac in a 12 bolt. Love the differential action for cornering exits but also complained of noise. The driveshaft could be rotated 45 deg w the wheels locked.
He renamed it True Slack and returned to clutch style.
[Re: crash520]
#1976715
12/26/15 07:57 PM
12/26/15 07:57 PM
crash520
Brisbane Australia
Yeah, I have to say I love the way it works through corners and burnouts, I love everything about it,,,,,,exept the damn noise, all they need to do is sort out the side gear float and they would be awesome. I dont want to go to a clutch, Ive had those before, a spool is just a PITA as is somewhat a locker on the street,
I JUST WANT A GOOD TRUTRAC Eaton sent me a warranty replacement but as indicated its equal to if not worse in side gear slop.
