Welders-dashinsert-what to use to clean up in tight spo #197402
01/18/09 06:27 PM
01/18/09 06:27 PM
Ky.
dart67 Online content OP
dart67  Online Content OP
Ky.
Hoping I can find some advice. I'm fabbing a dash insert for my 67. I need to grind down some spots (welds) but they are on the inside of the insert on the sides. I've done most of the welding from the back, but I have a few bumps to knock down. I have an air tool with what I think is a 3 inch wheel. Too tight of a spot to use it. Any ideas?
Thanks in advance, Kevin
Re: Welders-dashinsert-what to use to clean up in tight [Re: dart67] #197403
01/18/09 06:45 PM
01/18/09 06:45 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Dremil tool or die grinder with a small stone or rasp file
Re: Welders-dashinsert-what to use to clean up in tight spo [Re: dart67] #197404
01/18/09 10:14 PM
01/18/09 10:14 PM
Ky.
Ky.
I've got a Dremil, seems like it wouldn't do well on this. Maybe I'm not using the right accessories......
Re: Welders-dashinsert-what to use to clean up in tight [Re: dart67] #197405
01/19/09 01:31 PM
01/19/09 01:31 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Correct, there are tons of Dremel products. They have everything from mini cutoff wheels to carbide burrs. I use them a lot in tight spaces.
Re: Welders-dashinsert-what to use to clean up in tight spo [Re: dart67] #197406
01/19/09 04:15 PM
01/19/09 04:15 PM
Jacksonville Florida
elitecustombody Offline
I usually use my Snap-On Carbide Burr set, it has 8 different bits,they cut like butter, had to use it couple days ago when I sectionned a frame rail,I don't know what I would do without this set
Re: Welders-dashinsert-what to use to clean up in tight spo [Re: elitecustombody] #197407
01/19/09 08:50 PM
01/19/09 08:50 PM
Ky.
Ky.
Thanks for the help. I'll run by Lowe's and check out what they have.
