1971 Charger how many lbs of R12 refrigerant system need??
#1972126
12/18/15 02:32 PM
12/18/15 02:32 PM
Posts: 1,347 Wahoo Nebr
vette1986
Wahoo Nebr
Have a 1971 charger that I need to completely recharge the system as it was just opened up. How many lbs does the whole system use? Anyone ever try this stuff instead of the R12?
http://www.ebay.com/itm/6-MAXI-FRIG-12a-REFRIGERANT-OIL-STOPLEAK-R12-ADAPTERS-HOSE-GAUGE-1994-OLDER-/111852354784?hash=item1a0aeb7ce0:m:mDoB_UfSWFiD9_3Kvd2rwvA&vxp=mtr
1969.5 A12 Bee EV2 1971 Charger RT 1973 Duster tubbed 500 low deck 10.90 monster 3 440 polara vert projects
Re: 1971 Charger how many lbs of R12 refrigerant system need??
[Re: vette1986]
#1972272
12/18/15 07:18 PM
12/18/15 07:18 PM
Posts: 6,224 JERSEY
RJS
JERSEY
The tag on the compressor says it, 3.6 lbs. using R12 but a good guy will know by reading the gauges properly. Ron
[Re: RJS]
#1977328
12/27/15 07:18 PM
12/27/15 07:18 PM
Posts: 25,992 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The tag on the compressor says it, 3.6 lbs. using R12 but a good guy will know by reading the gauges properly. The only correct way to refill an empty system is by weight. All of those supposed R-12 replacements are blends containing mostly R-134...stick with R-12.
