Page 9 of 9 < 1 2 3 4 5 6 7 8 9
#2361123 - 08/28/17 11:08 AM Re: My bracket hemi build [Re: Triple Threat]
Triple Threat Online   content
Loc: Renton Washington
15 more runs Saturday. All on the throttle stop for 10.90 practice. Managed to win Super Pro and Super Street.
-Dustin
392" G3 Hemi
1.37, 6.17@111, 9.74@136.9
#2361583 - 08/29/17 07:47 AM Re: My bracket hemi build [Re: Triple Threat]
moparmitch Offline
Loc: Michigan
Congrats! beyond impressive...
#2361723 - 08/29/17 12:14 PM Re: My bracket hemi build [Re: Triple Threat]
ric3xrt Offline
Loc: Sellersville Pa
have you checked the rocker tips? how do they look
Truth has no agenda, but those with an agenda don't always acknowledge truth
2003 Ram st
2004 Rumble Bee
2005 Ram GTX
Any info on these trucks is greatly appreciated
2005 Ram 1500 (drag truck in building
2014 1500 tradesman(shhhh, it's hiding a 7.0 short block under those eagle heads.
#2361762 - 08/29/17 01:03 PM Re: My bracket hemi build [Re: Triple Threat]
The valve covers haven't been off since May of 2016.
I'll give them a look this winter as I'm planning to freshen the engine.
-Dustin
392" G3 Hemi
#2388105 - 10/16/17 10:34 AM Re: My bracket hemi build [Re: Triple Threat]
Well this season is officially in the books after yesterday. 194 runs on the year.
Also ran a new best yesterday, Incrementals
1.37
6.17@111.08 mph
9.743@136.90 mph
Only change from my normal bracket set up was tossing on a set of 325/50/15 drag radials. 2 inches less height and radial construction was worth quite a bit. The car still wants more gear, it likes shifting around 7300 but is only going through the traps around 6900.
-Dustin
392" G3 Hemi
#2388213 - 10/16/17 01:44 PM Re: My bracket hemi build [Re: Triple Threat]
sixpackgut Offline
Drag Week Mod Champion
Loc: Charleston
1.37
6.17@111.08 mph
9.743@136.90 mph
This post is deserving of a "new best thread"
On the class racer forums, they say that you want to hit peak hp at the 1000 ft mark. So if your peak is 7300 than you want to hit that at 1000ft and than pray you dont break a valve or spring the last 320 60ft
Edited by sixpackgut (10/16/17 01:47 PM)
#2388253 - 10/16/17 03:01 PM Re: My bracket hemi build [Re: Triple Threat]
There is a new best thread in race only, I'm keeping my updates here so everything is tracked in one location for people to follow along and to easily look back on the progress from 10.20's to 9.70's
I think 4.56's would be ideal for this engine, with a trap rpm of 7600+ that would take advantage of the acceleration early like the class cars do. However, with as many runs as I make I don't like the idea of leaning on it that hard. Someone else can have that honor and the glory.
Would be fun to put this engine in a lighter car. In bench racers theory, a <2800# car, 904 trans and more rear gear should be capable of high 8's
-Dustin
392" G3 Hemi
#2389358 - 10/18/17 01:43 PM Re: My bracket hemi build [Re: Triple Threat]
raceadodge Offline
Loc: wa.state
I hope I will be doing that very thing next year, but with a 2500# car 727 trans and 430 gears.
#2392060 - 10/23/17 08:09 PM Re: My bracket hemi build [Re: Triple Threat]
MattW Offline
Loc: Ontario Canada
I'm thinking out loud here and your car is impressive!
Could it be that your heads are too big?
Wonder if less flow top end , which most of the time = more mid range , would work better?
I was always under the impression that there are two ways to feed a port.
RPM or CID.
Once again impressive car!
Matt
#2392099 - 10/23/17 09:44 PM Re: My bracket hemi build [Re: Triple Threat]
Dragula Offline
Loc: Taxes R-US, NY
I am close to pulling the trigger on one of these. My Cuda weighed 3250 with an iron block Hemi and alum heads. Never got to weigh it qith the all alum 605 in it, but it felt lighter than anything else I have run in it...Figure one of these would put to 3100 or so....That little engine would run pretty good in my junker at that weight.
What compression is yours?
'71 Duster Pump Gas 512RB
https://www.youtube.com/watch?v=Z_XTmRBuvWs (6.19)
https://www.youtube.com/watch?v=gQZGfDBPROM (9.70 at 138.5mph)
'70 Cuda Hemi, 605 almost ready again.
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.31)
#2392178 - 10/24/17 12:40 AM Re: My bracket hemi build [Re: MattW]
sixpackgut Offline
Loc: Charleston
RPM or CID.
Matt
I have already posted on moparts my step by step port on apache heads and what to expect on flow. I do not make them big.
The stock port size is bigger than Chip's ports on his 572 hemi
Edited by sixpackgut (10/24/17 12:42 AM)
#2409427 - 11/26/17 09:58 PM Re: My bracket hemi build [Re: Triple Threat]
cudadoug Online   content
Loc: Between a rock & a hard place
Dustin when you first put this deal in the car, it fit under the Hemi scoop, right?
If I recall that correctly, what was the intake that you used??
Thanks!
#2409668 - 11/27/17 01:43 PM Re: My bracket hemi build [Re: Triple Threat]
Short Ritter 4500 with no spacer under the carb and no air cleaner it barely fit.
-Dustin
392" G3 Hemi
#2410123 - 11/28/17 11:08 AM Re: My bracket hemi build [Re: Triple Threat]
Thanks, Dustin.
25,067 Registered Members
185,576 Topics
Exhaust leak ??
by Jupiter331
01/16/18 03:30 PM
INDY 440-3RB VS INDY 440-2RB WITH 440-2A 2" RISER
by moparjohn
01/16/18 03:01 PM
M Code Lug Nuts
by hemiviper588
01/16/18 03:01 PM
Tire Size55
by Crabra
01/16/18 02:37 PM
